Question about Philips LX3600D System
Philips LX3600D Progressive Scan problems - Philips LX3600D System
  • Sachin
    Sachin May 11, 2010
    Can you please elaborate,, can't understand what problem have you got
    Problem Solver:
  • 7 Answers
Conect ur video cable to cymk output it apper picture and then in system seting reset the dvd player
Posted on Mar 06, 2009
Philips lx3600d dvd surround home theatre system dvd player fault
when the dvd is inserted it shows up no disc so it is not loading
Jan 09, 2010 | Philips LX3600D System
My Philips LX3600D returns always to stand-by mode
The speaker cables for the LX3600D are: (+) is blank, whereas (-) has slightly shaded bands along it. Once you see these bands its easy to open up the connector and check they are the correct way around.
Mar 15, 2009 | Philips LX3600D System
Progressive scan mode
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Mar 15, 2008 | Philips LX3600D System
Progressive scan
I too have tried scanning two different Philips 3390 DVD records with the same results. So far Philips have not come up with a solution. I would appreciate it if anyone out there could shed some light on this problem? It does not appear to be a one off situation.
Thanks in advance.
Feb 23, 2008 | Philips DVDR3390/37 DVD Recorder
Philips DVD LX3600D
just type in to google make-model of dvd player and region codes
and search for the one you want .
riz.
Feb 08, 2008 | Philips LX3600D System
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Philips LX3600D System Logo
176 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
