Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Connection to TV by HDMI cable
How connect 625 DVR to Vizio TV by using HDMI cable?
  • 374 Answers
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
Posted on Mar 06, 2009
Lost signal from dvr to vizio tv and need to know what type of cord is used for this connection
That would have to be either a HDMI cable similar to usb but not totally rectangle or the old 3 lead RCA to RCA cables which are red and white for audio and yellow for video.
Apr 14, 2014 | Dedicated Micros Televison & Video
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
Can I connect the usb port on the DVR-625 to a TV with a usb connection and get a better picture? ?
Hi Roy Yoerger!
You would not be able to use the USB connection on your receiver to get a better picture. To get the best picture on our Standard Definition receivers, I would recommend using Component (RCA) cables.
Tommy Faust
DISH Social Media Representative
Feb 25, 2012 | DISH Network DVR-625 DTV Receiver /...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
I have a DVR from my cable company which I recently replaced. I have the cable coming to the DVR, then out to my RCA DVD recorder, then out from the DVD to my Vizio TV. I have an HDMI cable connection...
IT SOUND LIKE THERE SHOULD BE AN INPUT BUTTON ON YOUR CABLE OR T.V REMOTE TRY CHANGING THE INPUT. ALSO TRY PLUGGING DIFFERENT AUDIO AND VIDEO CABLES BETWEEN RECORDER AND TV. ALONG WITH YOUR HDMI.
Oct 22, 2009 | RCA Televison & Video
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
428 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
