Question about Microsoft Windows Vista Ultimate Edition
C++ do not work properly
My c++ compiler cannot open hedar file
  • 304 Answers
Download C-Free_v3.5.2 from google. It will work on vista also.
Posted on Mar 06, 2009
Codes of c++
Microsoft Visual C++ 6.0 is an integrated development environment, or IDE, released by Microsoft in 1998. An IDE allows the user to create a computer application by using pre-designed functions, tools and other resources. Microsoft Visual C++ 6.0 features a source code editor, a compiler, a debugger and graphical user interface.
Install Microsoft Visual C++ 6.0 on your computer. The installation process is fairly simple. Just follow the prompts. Run the program. A window will appear asking you to create a new application. On the "Project" tab, choose "Win32 Console Application." This means that you will create an application with an EXE file extension that can work with 32-bit Windows operating systems after compiling the project. Also, specify the project's name and the location where it will be saved. Click "OK." Click"OK" in the dialog box that will appear next. You will choose to start an open project. Double-click on the form in the center of the screen. Type: #include <iostream.h> int main() { cout <<"This is my first project!!! Hello everybody! \n" return 0; } Press "F5." This will build and run the project. Microsoft Visual C++ 6.0 will compile your project into an EXE file. Then it will open this file. You will see a new window open in which you'll see your greeting, " This is my first project!!! Hello everybody!" Press any key to exit the application. http://elvis.rowan.edu/~kay/cpp/vc6_tutorial/ http://msdn.microsoft.com/en-us/visualc/ee340952.aspx
Feb 03, 2013 | Microsoft Visual Basic 6.0 for PC
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
Java Vitual Machine Launcher prompts this message "Could not find the main class. Program will exit" How can I solve this problem? I need urgent assistance.
You need to compile the .java file you have, and run the .class file that is produced.
Open up command prompt, go to your working directory. If your file was called Hello.java: In command prompt type "javac Hello.java". Now, in the working directory, you will see a new file, Hello.class. Run that file by "java Hello.class". Hope this helps!
Thanks for using FixYa
Aug 20, 2011 | Sun Java Programming Language (cdj-275)
How to convert vba macros to visual studio?
  1. Clean your code. There are built in Application specific functions which don't work in VB Studio. Some will require you pre-load the application first, others just don't work at all.
  2. Save the VBA module as a BAS file. This is just a text file with the module code in it.
  3. Export your forms to file.
  4. Open Visual Studio
  5. Import your forms and modules
  6. Clean it up.
  7. Compile it
Apr 28, 2010 | Microsoft Visual Studio 2008 Professional...
Needs a winasp123.dll to work properly. please help?
That file is here 2nd, link below, however that file is to do with ASPI, and burning CD/DVD go to the first link, and have a look there.. http://www.afterdawn.com/guides/archive/aspisetup.cfm
http://www.dll-files.com/dllindex/dll-files.shtml?wnaspi32
Feb 27, 2010 | Computers & Internet
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
I CANNOT OPEN THE FILE APPEARS CORRUPTED
What file is it?
Check the Extension make sure you are opening the file with the correct programme
Check google for details of what programmes open what files
If this helped please vote!
Sep 21, 2009 | Computers & Internet
Error occur during compiling,unable to open a header file
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Apr 15, 2009 | Computers & Internet
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
regards
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
Dogz/Catz 5 compilation Vista Help
Firstly, open a folder. You need to click on 'Organize' >> 'Folder and Search Options'. On here click on the 'view' tab, then check the box for 'Show hidden files and folders'. Click OK on this.
Next go onto C: and click on your user name, then click on AppData.
In here, click on 'Local' >> 'VirtualStore' >> 'Program Files' >> 'Ubi Soft' >> 'Studio Mythos' >> 'Petz 5' >> 'Adopted Petz'.
Here is the file path if you need it:
C:\Users\Your User Name\AppData\Local\VirtualStore\Program Files\Ubi Soft\Studio Mythos\Petz 5\Adopted Petz
Hope this helps!
Jenn xo
Sep 15, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Microsoft Windows Vista Ultimate Edition Logo
15 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
