Question about Toshiba Libretto 100CT Notebook
Toshiba libretto BIOS Reset
Ok,, so a friend gave me a token.. Toshiba Libretto ff 1100ct..
the problem is the password upon pressing the ON button..
i can't get into bios setup because of it..
can anyone help me remove the password or reset it????
  • lam_6651 Oct 24, 2009
    prblem solved...
    thankz for d big help ...
  • dubosecraig May 11, 2010
    If there is a password that is not allowing you to reset the BIOS, I would recommend going to the following website and having one of the technicians use their proprietary devices that can unlock it for you. Im not sure if there is a charge but this may be the best solution to avoid any headaches. Just let them know there is a bios password preventing you from entering the BIOS and you need it removed and they should be able to help you from there.
    http://www.csd.toshiba.com/cgi-bin/tais/...
    Problem Solver:
  • 9 Answers
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
Posted on Mar 06, 2009
Testimonial: "thankz alot.. best techncal site ever "
SOURCE:
Toshiba libretto 50 ct wont boot
I haven't encountered multiple beeps on shutdown - but multiple beeps on startup is usually an indication of a memory issue. Frequently can be resolved by simply taking memory modules out and re-inserting them.
If problem continues, may need to replace memory chip. If more than one chip, put one in at a time and startup to see which chip is causing the problem.
Not sure, based on your description of the problem, if this is the issue - but certainly worth a try.
Best of Luck!
Jan 03, 2013 | Toshiba Libretto 50CT Notebook
My toshiba libretto laptop won't turn on how do i fix it
first, I will advice that you check the adapter, see if its still working. The adapter might be the reason your laptop is not working.
If you have confirmed that the adapter is still good, let me know so that I can direct you further.
Take care.
May 28, 2010 | Toshiba Libretto 50CT Notebook
Does anybody know if a Toshiba Libretto U100 can run on a DDR PC2700 333 1Gb ECC so dimm?
Go to www.crucial.com
They will run a test on your laptop and tell you exactly which memory will work on your machine
It is free and safe
Jan 29, 2010 | Toshiba Libretto U100 PC Notebook
Need to boot into BIOS to change IDE setting. No Floppy drive.
hi
To enter the BIOS during start-up press the ESC-key while switching power on
hope this helps :0)
May 19, 2009 | Toshiba Libretto 50CT Notebook
I cant reformat my Toshiba libretto L3. I tried everything
You cant boot from cd. Try changing the boot order in the BIOS and allow the CD to have ownership over the Harddisk Drive. This way the computer is forced to boot from the CD.
Jan 16, 2009 | Toshiba PA2502U - Libretto 100, 110,...
Can you give me driver of Toshiba Libretto L3 sound card? Thanks
I would recomend upgradeing to XP. If thats not an opption go to the toshiba web site support portion. No luck? Driverguide.com they have millions of drivers for pretty much anything.
Jan 14, 2009 | Computers & Internet
TOSHIBA LIBRETTO 50CT NEEDS LINUX
Hello there
If you haven't got it already, download "Freespire" its a free linux download and really easy to use!!!!!!
It comes equipt with all the software you will need and a automatic updater which will download anything you need for the system.
Its easy to set up your internet and use office software (you can even view microsoft docs), with this you can even connect and chat to MSN, Yahoo etc
give it a go you will like it!!!!!!!!!
Kind regards
Dec 14, 2008 | Toshiba Libretto 50CT Notebook
How to overcome 8.4gb bios limit on a toshiba libretto 100ct?
Ok get a program called Partition Magic, I have found you a Tutorial here: http://www.le.ac.uk/cc/dsss/docs/pm4-main.shtml Basically, you divide the 8.5GB into smaller sizes, NO MORE than 4GB, so say 2x3GB, & 1x2.5GB, or whatever suits.. then ya Format each Partition, Make ONE an Active Boot Partition, the rest logical ones. Your actual Size of the drives will be less than the Total due to Formatting information etc. Read the tutorial carefully B4 ya do anything. Ya be using the bigger storage in no time...
Aug 14, 2007 | Toshiba Libretto 100CT (P000249540)...
Toshiba Libretto 100CT Notebook Logo
925 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
