Question about Panasonic TH-42PWD8 42 in. EDTV-Ready Plasma Television
Um...well i connected an xbox 360 console to your tv model TH-42PWD8WK/S and it was working for about half and hour then it suddenly switched off and the tv stopped working so i was wondering, is this tv model compatible with gaming consoles?
  • 60 Answers
If it a flat screen tv i would recommend u use a HD tv wit ur xbox
Posted on Jul 17, 2009
My sons xbox 360 dosn't read that any cables have been connected
Since you already exhausted all the steps to isolate the problem, The probable causes of this issue is the AV PORT is faulty.
You might wanna contact xbox customer support to check the warranty status of your console, hope you still have warranty so that you can send it in for free.. Goodluck
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Jan 18, 2009 | Microsoft Xbox 360 Controller
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
Three red lights and no picture
I had the same problem my xbox 360 just broke all of a sudden and then I used this guide to fix my xbox 360 plus it only takes like an hour. Good luck dude.
fix360fix.com
Sep 16, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360
Depending on the type of Tv you have look for the Red Blue and Green RCA Compsite jacks on the back and the Left and Right Audio Which are Red & White Plug them in and Check the connection by turning th 360 plug to HD (near the console) and turn it the Tv and 360 on (make sure the Tv is on the right input) and that should do it.
Feb 14, 2008 | Microsoft Xbox 360 Console
To play this disk, put disc in an xbox 360 ? um, it is in one. duh
same here it happens every day and its driving me crazy
Dec 28, 2007 | Microsoft Xbox 360 Console
Xbox 360
Switch the external power supply with a friends to make sure it's bad, then go pick up a new one at $100 or used around $59.99. Pricey, yes, but remember it's an external power supply, everyone else has that built into the console.
Feb 11, 2007 | Microsoft Xbox 360 Console
Panasonic TH-42PWD8 42 in. EDTV-Ready Plasma Television Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
