Question about Canon i9950 InkJet Printer
Ink pads need replaced
HOW DO I REMOVE THE COVER TO GET AT THE INK PADS TO REPLACE THEM,AND HOW DO I RESET COUNTERS.
  • arthur davidson Mar 06, 2009
    Hi Nic,
    The user manual does not shoh how to strip the outer casing of printer to get at ink pads.Thanks a million for your help.
    Artie.
    Thanks for trying mate but what these pages are referring to are changing ink tanks,but what I need is how to change the ink residue catch tanks(pads) which means removing the outer cover to get at them.
    Many Thanks
  • 3 Answers
Don't know if you managed to get the cover off, but I just did, first you have to remove the 2 silver end plates, they are held on by 2 clips each, use a thin bladed screw driver and push it down into the holes marked with an arrow, one on the rear under the rear lid, that you stack the paper against, one on the front inside the front drop down cover that the paper comes out on. then release the four arrowed clips along the back and side of the printer and another 2 on the front, one on the cd lever side, and 2 on th eswitch side, one of these is hidden behind the switch panel which you have to remove and unplug, then the whole cover should just lift off
Posted on Aug 09, 2010
    President:
  • 1,073 Answers
Hi!
Here is all the manuals for that printer of yours:
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=Printers&series=Colour+Bubble+Jet+Printers&model=i9950&menu=Manual
And here is a Printer User Guide for Windows users:
http://software.canon-europe.com/software/0023124.asp?model=
I hope that help you solve your problems
Good luck
Nic
Posted on Mar 06, 2009
  • Nicolas
    Nicolas Mar 06, 2009
    Hi Artie!
    It dident?...damn my friend!..wait..let me see if i can find anything else to help you M8!
    Hang on..i will be back
    Nic
  • Nicolas
    http://gdlp01.c-wss.com/gds/2/0900005642...
    There u go, take a look on page 5, 6. 7 and 8.
    On those pages you will see precisly how to do it!
    Good luck my friend
    Nic
    Pls, reconsider to change the rating you gave me IF you feel that i solved your problem now
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
T60 printer service requier
Hi if you got this massage it's means that parts in your printer get to finish of their life and you suppose to send it to Epson for service. Have a look here Epson Ink Pads Reset Utility . There is a software which allows you to reset your printer counters but this is just part of the service, you need to replace ink waste pads, container or diverted the waste ink to some bottle otherwise ink gonna be split inside the printer everywhere.
Apr 21, 2014 | Epson Stylus Office Equipment & Supplies
The printer's ink pads are at the end of their service life. Please contact Epson support.
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Both the red and green light are on and blinking.What is wrong with my Epson C60?
kiryakitsa1 You should download the SSC Service Utility as pineworks says. Read the instructions and warnings. Go to Reset counter protection and press reset. You may recieve a warning about replacing your waste ink pads. I have always reset the protection counter without replacing the waste ink pads and I have never had a problem. If you see ink drainage then you should replace the waste ink pads and then reset the protection counter. I have never had a problem with ink heads and I have done this many times.
Feb 07, 2010 | Epson Stylus C60 InkJet Printer
Dirty Waste Ink Pads (Epson Stylus R285)
Remove to top cover and replace the ink pad with a new one. You can get these pads from a place called pudsey computers www.pudseycomputers.co.uk
Nov 17, 2009 | Epson Office Equipment & Supplies
What is a The waste ink absorberves
The waste ink absorbers on a Canon are a set of pads underneath the entire printer engine, they cover just about the whole bottom of the machine, on a Brother it's a replaceable box filled with absorber pads. Both have to be replaced by a shop to reset the counters and clear the error.
Aug 11, 2009 | Office Equipment & Supplies
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Canon i9950 InkJet Printer Logo
314 people viewed this question
old marine
old marine
