Question about Microsoft Windows Server Standard 2003 for PC
How to recover windows 2003 server after crash the window easy.
We have server 2003 standard edition
no floppy drive
  • 113 Answers
Do you created backup?
Posted on Mar 06, 2009
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
Files deleted from server
There are several software solutions that can recover deleted data, assuming it was just deleted and not securely deleted (where the file is overwritten many times) and if that particular part of the hard drive has not been written to since deletion. I assume you checked the recycle bin and it wasn't there in which case you may be able to recover the file(s) if you are able to get a program to recover them quickly enough. A google search should turn up dozens of such programs.
Aug 05, 2009 | Microsoft Windows Server 2003 Standard...
Windows 98 crashes while I am accessing a share from a server
The OS may not be compatible for Server 2003, The best thing that you can do here is to upgrade your operating system to Windows XP or Windows Vista for full compliant on Networking.
Jul 29, 2009 | Microsoft Windows 98 Second Edition OEM...
How can I mount an IBM AIX hard drive in Windows?
AIX uses a file system that is not supported by Microsoft Windows. Most likely you will need another AIX system to read the file system. I recommend that you contact a hard drive recovery service like Ontrack Data Recovery and get some guidance.
You should remove it from the Windows computer ASAP. Windows has the habit of making changes to any disk it sees and you may lose everything!
I hope this helps.
Jul 17, 2009 | Microsoft Windows Server Standard 2003 for...
Ntbackup causing server to crash and reboot
Try to monitor the memmory and processor usage in task manager  performance tab.Check you have sufficient memmory sixe in your server.
Oct 17, 2008 | Microsoft Windows Server Standard 2003 for...
Disable usb pendrive,cd rom and floppy in win2003
You can lock the USB drive by editing the registry. So I’ll tell the key name and the value, that you have to create for the restriction. If the key is not present, then simply create it.So here we go:
Restrict Writing to USB Drives:
HKEY_LOCAL_MACHINE\SYSTEM\Current Control Set\Control\StorageDevicePolicies
Create DWORD value WriteProtect and set its value to 1
ALso, please click on the link mentioned below for more information:
http://support.microsoft.com/kb/278295
http://support.microsoft.com/kb/231289
You can also use third party software to lock the USB drives:
http://lock-usb.qarchive.org/
Thanks
Aug 20, 2008 | Microsoft Windows Server Standard 2003 for...
Raid 5 failure
to recover your data is very easy. just slave your hdd to a system that is working fine and switch it on.after windows has succesfully loaded go to my computer you will see to hard drive.the slave hdd will be labelled B.double click on it go to my documents and copy all your filesand save it on your working hard drive.after copying make sure you remove the slave hard disk
Jan 31, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
