Question about Bauknecht Dishwashers
Bauknecht GF7199 F7 light has come on
Dishwasher moved while retiling floor. Now F7 light on.
    Genius:
  • 1,550 Answers
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Posted on Mar 06, 2009
  • maximilian
    maximilian May 15, 2014
    Thanks a million !! it worked instantly. I had no idea how to reset :O)
How do i work out square meterage for a bathroom (floor and walls)? I need to retile
Multiply length by height in metres for each wall, and add up all these wall areas. Then multiply length times breadth for the floor, not forgetting the shower. If it is irregular in shape, divide it up into rectangular sections, measure each and add together for a floor total.
You will need then to add about 10% to floor and wall totals for wastage.
You don't say whether you are tiling yourself, but take special care in waterproofing in the shower and under the bath, if any. Also take care with the fall to the floor drain in the shower recess, if any.
Mar 06, 2015 | Home
Error code f7
Hello Samir Girgis - Typically F7 indicates that it is a potentiometer failure error code has occurred and indicating that one of the surface burner switches has failed. Contact a professional to move forward accurately and to assist with the repairs.
Feb 15, 2013 | Electrolux Frigidaire Professional Series...
Clean light is flashing
please read your instruction manual and go the section troubleshooting
press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
Jun 21, 2012 | KitchenAid KUDS30IVBL Builtin Dishwasher
I turn on the dishwasher you hear a cycle of water and then turn on the light F7 and the dishwasher stops.
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck,
Mar 28, 2011 | Dishwashers
Dishwasher won't start - I get an F7 message on my ADP5966
Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter
Dec 17, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
When the washing machine goes into spin it sounds as though a plane is taking off and the maching rocks/moves on the tiled floor. We had this problem though not as often before the floor was retiled due...
there are two causes to this problem.1 at the top of the machine is a balance,cement brick [it may be broken]it balances the drum.2 adding a small load/ie;one towel;one item etc,or small items.adrian,,,,,
Aug 09, 2010 | Bosch Washing Machines
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
ADP 7966
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work.
The following worked for me:
F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Oct 22, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
F7 fault
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work. The following worked for me: Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Apr 14, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool dishwasher ADP5962 F7 error code
emmanuelr is spot on with this advice. The dishwasherr had been idle for a few months so as advised disconnected and reconnected the connection to the water flow meter and job done. My friend you are a scholar and a gentleman thank you so much. You are not an apprentice to me.
Dec 03, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwashers Logo
1,753 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
