Safari Version 6.0.3 (8536.28.10) Is asking to verify a site certificate when there is not an issue with the site certificate. I have check my date and time, updated correct. I have gone to many sites and seen where others have tried many difference types of fixes, reseting chain, reseting Safari and even changing IP addresses. These are not for me. I think some needs to fix Safari Version 6.0.3 (8536.28.10) and create a patch for this version.
SOURCE: Safari Crashing
I had a problem where Safari 1.0 v85 was crashing every time I visited
a page with Flash graphics on it. delete the preference file named com.apple.Safari.plist while Safari is closed
then it work properly
SOURCE: Safari Not Responding
Hi there.
The problem is the internet not the web browsers, and it depends what time of day your trying to connect to a certain site, this is because 99% of ISP's have taken on a fair usage policy which means at certain times of the day your connection speed is capped to the internet doesn't get clogged up.
I use a Windows PC with a 50meg connection and i experience the same problems with certain sites.
The only thing that i can suggest you do is update your java and flash (macromedia) software and see if that helps at all.
Good luck and thanks for choosing FixYa!!
SOURCE: safari table width problem
Safari fully passed Acid3 test (http://webkit.org/blog/280/full-pass-of-acid-3/) so, how Safari showed width of your table is how you designed table width...
SOURCE: Safari crashes every time I open it after 5.0
You may try uninstalling and reinstalling it a gain. Usually this helps.
It can also due to Low RAM
Cheers,
KA
SOURCE: I can't sign on to my AOL mail account Using Safari 4 browser
Can't access my AOL mail through safari. HELP!!! Please advise
Many Thanks
