Question about Sony KP-61V90 61" Rear Projection Television
Convergence the auto convergence setting is not functioning. when the option is selected colours aren't alind and as such ther is a poor picture quality.
  • bakercar Mar 09, 2009
    thank you for the support.I do know how to solder and would like to attempt repairing of my convergence, myself, so if there is any additional information u can give, I would be very greatful. Thank you.
  • 4,234 Answers
This can be as simple as poor connections on the convergence ICs or defective ICs. If you can solder you should be able to repair this yourself. Please let me know if you wish to attempt the repair and I will provide additional details and instructions.
Thanks,
Dan
I'm not sure which question will be returned to you, so I have prpovided hte same solution/request in both. Please only update one. Thanks
Posted on Mar 06, 2009
My sansui rear projection tv's picture is concave with convergence problem also how can i fix it
The convergence can become unstable if you have a failing colour wheel if a dlp set. the same thing can happen if your lamps is beginning to fail the poor frequency of light from bulb disrupts picture. Convergence is usually done by entering service technician code into set through the remote and entering the engineering sub menu and if you don't know what your doing or have a colour pattern generator you could make things considerably worse .
Jul 01, 2015 | Televison & Video
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
The covergence
I have a kp-61v90. I love this tv. Recently the flash focus isnt working,,,,, the colors are not lining up to give me a solid cross in the middle so it makes everything look as if i were wearing 3-d galsses. Yes i can solder, but what am i soldering. Help me please....my man cave is out of commission.
Mar 06, 2009 | Sony KP-61V90 61" Rear Projection...
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
Poor quality picture while playing ps2 games?
i think you should try other modes too like pal and others or in many tvs there is a option auto so the tv automatically select the best mode of color itself.....
Jan 20, 2008 | Sony PlayStation 2 (PS2) Console
No sound
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Jul 28, 2006 | Sanyo C40N
Sony KP-61V90 61" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
