Question about Sony KP-61V90 61" Rear Projection Television
The covergence the tv has a auto convergence, which isn't functioning properly. The colours aren't coming together to make one the red is sticking out. As a result the picture quality is very poor.
  • 1 more comment
  • bakercar Mar 06, 2009
    ok Dan thanks for that tip. Yes I can solder and I want to attemp the repair myself.
  • bakercar Mar 09, 2009
    Thank you for your support. Yes I know how to solder and would like to reapair it myself. I am interested in your additional details and instructions thank you.
  • Robert Camp Apr 04, 2009
    I have Auto convergence, but the Colors do not converge correctly on the the corners and bottom. Is there a way to get in there and manually adjust the colored cameras by aligning the different crosses around the screen? My KP-61V80 rear projection only gives me the flash focus option, is there a way to get into the other program, to manually adjust? If so, how can I get in?
    Problem Solver:
  • 9 Answers
I have a kp-61v90. I love this tv. Recently the flash focus isnt working,,,,, the colors are not lining up to give me a solid cross in the middle so it makes everything look as if i were wearing 3-d galsses. Yes i can solder, but what am i soldering. Help me please....my man cave is out of commission.
Posted on Jun 22, 2009
  • 4,234 Answers
This can be as simple as poor connections on the convergence ICs or defective ICs. If you can solder you should be able to repair this yourself. Please let me know if you wish to attempt the repair and I will provide additional details and instructions.
Thanks,
Dan
Posted on Mar 06, 2009
Auto covergence will not converge
Try this with tv turned off press and hold at same time the vol- and ch- wait untill TV comes on then release Buttons,TV will either start auto convergence or you will be in the service menu to adjust convergence.
Jun 26, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
There is no picture when TV is turned on and all you hear is a faint chirping sound. Sounds like something is trying to restart. There was an issue with our cable, once it came back on later in the day the...
The problems ur tv having is also parts of the tv Convergence board are dead,but it is totally dead to causes this problems,if convergence board it still have some functions left.Tv will only have colors R,G,B will mis alignments,have colors shadows pictures and 3D pictures look alike,but convergence board are not getting any voltages at all that why u just hearing faint chirping noises that it.The tv convergence board,must require to changes 2 STK convergence ICS and some or all of it resistors too.For the covergence board have fully functions again to solved this problems.The shop will cost u like $300-350 for parts and labors.
Jan 31, 2011 | Philips 60PP9202 60" Rear Projection...
Ghost images . all 3 colours auto convergence doesnt help
rear projection tvs are not easily repairable  there is no solution but an expensive replacement of all 3 picture tubes    it is basically a disposable tv   time for a new one
Nov 03, 2009 | Zenith R56W36 56" Rear Projection...
Red out of focus
Hi. your convergence board is failing. this board regulates the the alignment procedure and , the chip set is damaged. replace the convergence board soon.
May 22, 2009 | Toshiba 42H81 42" Rear Projection...
Convergence module
That 's actually a very reasonable price for a convergence board replacement in that TV. You can expect elsewhere to be double that or more. Unless you know electronics in TVs I don't advise trying to repair it yourself.
C-Dog
Jan 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Three colours don't converge
Shrink, the convergence circuit needs to be repaired, Until someone gets in there and takes a few measurements it`s hard to say what the cost will be, may just need to be re-soldered, good luck, BMW Rider
Dec 18, 2007 | RCA P46810LV 46" Rear Projection...
Zenith R56W36 covergence problem
you will need to replace conv ic's then auto converge..
Oct 19, 2007 | Zenith R56W36 56" Rear Projection...
Sounds like your convergence power supply board is bad if it is a ctc or ptk 195 chassis. Located above the main board on the left and dynamic convergence board on right. Has two plugs and held down with quarter inch screws. Most problems on the board is the IC on the metal heat sink which is stk 730-010. whatever you can see the part number on it. Unsolder with solder wick and solder in new. If this doesn't fix a new complete board will do.
Sep 09, 2007 | RCA P46922 TV
Sony KP-61V90 61" Rear Projection Television Logo
399 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
