Question about Whirlpool AWM5145/2 Front Load Washer
Need to fit a new door seal on my front loading washing machine, HAVE REMOVED THE OLD SEAL but can not get the new seal fully on. DO I need to remove the drum to fit the seal
  • 40 Answers
The easy way to do that if you have not done it before is to take top panel, control panel and the front panel off then you can easley get it lined up and on correctly be sure that the seal is completely in grove around the tub or the clamp will come loose two or three loads later and you will have a mess
Posted on Mar 08, 2009
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing machine replacement door seal
This video will show you how to change a door seal on this bosch Axxis WFL 2060
Oct 26, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal De
