Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo 3000 N100 problem starting
Screen reads:
We appologize for the inconvenience, but WIndows did not start successfully. A recent software or hardware change may have caused this.
If your computer stopped responding, restarted unexpectedly or was automatically shutdown to protect your files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked.
If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you aren't sure what caused the problem, choose Start Windows Normally.
Safe Mode
Safe Mode with Networking
Safe Mode with Prompt Command
Last Know Good Configuration ( your most recent settings that worked)
Start WIndows Normally
Use the up and down arrow keys to move the highlight to your choice.
Seconds until windows starts: 30
**Each selection was highlighted and attempt. Each attempt resulted in the Windows Icon appearing then returing back to the screen with the above directions.
Also I tried pressing the rescue and recovery butoon (F11) and the same result occured.
Do you have any suggestions for this problem?
  • RyanTM Mar 06, 2009
    Hi
    This is RyanTM. I can get passed that screen on the Lenovo 3000 N100 desktop I was reffering to. Therefore I cant download onto it. Do you have another suggestion?
    Thanks
Why does my Lenovo cant start up windows.
Try to perform full restart, press power button down until computer shuts down (+5 seconds). Then try to restart it. If repair function is offered, do not select that, select "start up windows normally".
Apr 24, 2014 | Computers & Internet
WHEN I TURN MY WINDOWS XP ON IT HAS A BLACK SCREEN WITH WHITE WRITING SAYING, WE APPOLOGIZE FOE THIS INCONVENIENCE, , BUT WINDOWS DID NOT START SUCCESSFULLY. A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT...
Try safe mode.
If that works, there is a card or software that has failed.
Checking the cards is easy, take them out one at a time and restart, for motherboard features, shut them down one at a time.
For software, did you load anything new, even updates, if so remove them.
Mine turned out to be a bad PCI card for a scanner.
Feb 18, 2010 | Computers & Internet
Were appologize for the incovience, but windows
you have to navigate the screen with the arrows and press enter on the option to select it......i would recommend starting up windows in safe mode just incase, let it load, then restart your system by selecting restart in windows.....now all should be fine!! :D
Pls rate this post and let me know if that was what you needed!! :D
Oct 08, 2009 | Dell Dimension 3000 PC Desktop
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My Lenovo N00, 3000 notebook came with a 10.8
boot up holding f8 key load last known good configuration. your computer should not know jack about the battery. but with computers you can never tell they are finikey
Jun 24, 2009 | Lenovo 3000 N100 Notebook
Recently my laptop, lenovo 3000 N100, has a power shortage
if there is a option saying boot in safe mode wtih out networsk try that
also press F8 you will see some extra options try that tooo that will work i did it in a virus affected system
i think the sole reson is some boot files are missing. if the above ones dont work try reinstalling
Jun 17, 2009 | E-Machines eMachines Desktop PC
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Well knackered
Restart in Safe Mode (Option 1 on the list) - when you get back on the desktop - uninstall the last you installed before the crash.
If you cannot get back on - locate the Recovery CD, put it in the drive and reboot from it. See if it will give you the choice to reinstall Windows in a NON-DESTRUCTIVE method.
Dec 02, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Problem with integrated webcan Lenovo 3000 N100 notebook
Buy external webcam; troubleshoot this problem was westing our time.
Nov 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
337 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
