Question about Tomtom ONE 130 GPS Receiver
I can't turn my TomTom 130 on. Charged it for 3
I can't turn my TomTom 130 on. Charged it for 3 days. The light is green at the bottom when I plug it in but it won't turn on. Only turned it on twice since I purchased it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
Try doing a reset. Hold the on/off button down for 20 seconds.
Hope this helps
Posted on May 11, 2009
How do I start my tomtom 2405. It has been sitting for 1 year. Charged overnight. The start button is green
Have you tried to RESET it ? .... either, hold down the power ON/OFF button for a long while ... (e.g. 30 seconds or more) ... until the device starts up (then let go)..... or use a pin (paper clip) to push into the RESET hole at the bottom of the device.
May 11, 2014 | Tomtom GO 2405 TM GPS Receiver
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
My tomtom won't turn on when I've charged it for several hours in the car and now at my computer. The green light is on but I still can't get it to turn on.
try the usb cable to your. this is the recommended method to charge a tomtom2.gif when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
Oct 15, 2009 | Tomtom GO 700 GPS Receiver
Our tomtom one 3rd edition stopped working it will not switch on or charge up even th ough green light comes on charger when plugged into car
try resetting it, but first put it on the charger for a few hours to make sure its charged. using a paper clip or something similar, depress and hold the reset button located on the bottom of the unit for 15 seconds, then hold the power button for up to 5 seconds till the unit starts.
if that fails, hook your tomtom to your computer and run tomtom home and see if that will update or repair it.
tomtom
let me know if you need further help.
bill
Aug 26, 2009 | GPS
Tom Tom not working
hold the power on button down until it turns on, does this help, also being plugged into charger with green light coming on normally means that the unit is charged.
Jun 21, 2009 | Tomtom ONE GPS Receiver
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
My tom tom does not turn on the green light is on when device is plugged in
I got the TomTom for my husband and it warked fine for 2 days and now it will not turn on at all.
It was feo our 40thAnniversay. Now it will not work. Please help me. They would not take it back at Wal-mart because of the time limit.
Jul 28, 2008 | Tomtom ONE GPS Receiver
Switch on problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 09, 2007 | Tomtom One Europe v2 GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Open Questions:
My tom tom one 130 stays with an orange picture, and a red circle with an X. It also says something about an error when I try to upgrade it... like this.... ERROR: Internal/Malformed#createItemFromDLL/Internal/Malformed: Exception: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Malformed Item info: name = id = version = 0 locationType = 1252 install location physicalType = 1504 metadata = Severity: 1105 - Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/model/ttItemFactory.js:43 let wrapper = new Exception(null, newId); 1. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 2. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 3. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 4. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 5. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 6. chrome://tthome/content/logic/dllUtils.js:58 this._success(); CAUSE: Internal/Malformed: Malformed: Lo sentimos pero HOME no puede completar esa tarea. Inténtelo de nuevo más tarde o póngase en contacto con el departamento de atención al cliente. Para resolver los problemas con los elementos almacenados en su dispositivo, le recomendamos eliminar y volver a instalar el elemento. Must not be empty Bad value: "" (type: string) Severity: 1105 Stack: 0. chrome://tthome/content/logic/serverinput.js:84 throw new Malformed("Must not be empty", uc); 1. chrome://tthome/content/logic/serverinput.js:218 var str = this.nonemptystring(uc); 2. chrome://tthome/content/logic/model/ttNavItem.js:265 this._idstr = makeSafe.contentidstr(item.id); 3. chrome://tthome/content/logic/model/subtype/ttVoice.js:36 ttNavItem.prototype.importFromDLL.apply(this, arguments); 4. chrome://tthome/content/logic/model/ttItemFactory.js:39 result.importFromDLL(item); 5. chrome://tthome/content/logic/model/ttItemFactory.js:90 var modelitem = this.createItemFromDLL(dllitem, onlyType); 6. chrome://tthome/content/logic/model/ttItemList.js:55 var models = gApplication.itemFactory.createItemListFromDLL(dllItemList, onlyType); 7. chrome://tthome/content/logic/ttTask.js:315 itemList.addItemListFromDLL(doneLocation.deviceNavItems()); 8. chrome://tthome/content/logic/util.js:79 return func.apply(obj, arguments); 9. chrome://tthome/content/logic/dllUtils.js:73 this._successCallback(this.successText); 10. chrome://tthome/content/logic/dllUtils.js:58 this._success();
Aug 17, 2010 | Tomtom ONE 130 GPS Receiver
See all Tomtom ONE 130 GPS Receiver Questions
Tomtom ONE 130 GPS Receiver Logo
717 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
