Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Printing from Adobe Illustrator
I have a bizhub C253 and i print my promotional materials with it. Printouts are consistently poor with texts being very blur. Tried upgrading the firmware but the problem still persist.
  • 101 Answers
Try to retarget work of your printer under your type of the used paper. Such parameters as density of the paper can have important importance. Try to print one and that document on miscellaneous type papers
Posted on Mar 07, 2009
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C253 "Id & Print" on Mac OS X
Ok this might not be much help but there is an option in the menus to 'print without authentication' you need to go to the control panel on the copier, press the utility/counter button to the right of the touch screen, press administrator settings for which the password is 12345678 then press number 4 user authentication/account track, then number 4 print without authentication, if you turn this option on it will allow you to print from mac, you will need to confirm this with whoever checks the account track as it may not then monitor any of the print jobs. Hope this helps
Jun 25, 2013 | Konica Minolta bizhub Office Equipment &...
I am using a Bizhub C550. I want to print an Illustrator file without maing it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like rinting through Illustrator ai instead of I
The easiet way is to open all trays and load the bypass and tell the machine you loading 8.5 x 11 on bypass.
You can also set it on any tray within the menu of the copier under paper > then select tray > then change paper tray settings. Usually it is set to auto. but you can change bypass to what ever size you want with respect to the spec of the machine.
Jul 12, 2017 | Konica Minolta Bizhub C550 Color...
Epson Stylus NX410 won't print in Adobe Illustrator CS
Try to print your file in jpeg or tiff format.Good luck!
Jan 12, 2010 | Epson Office Equipment & Supplies
Trying to print double sided in illustrator cs2 and can't seem to do it anybody help i'm fairly new to illustrator.
you will need to check if your printer has a duplex printing capability. No use trying to print double sided if it can only do single sided printing.
Nov 04, 2009 | Adobe Illustrator CS2 Full Version for PC
Printing everything double sided
go in youre ip address, log in as admin, chooce print tab and there is a print tab, there is a default options, and choose double printing off
Oct 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Problem Printing accurately colors from Corle Draw to Bizhub C252
The reddish greys are something a Fiery will correct, that is part of it's function. (GCR).
I would try turining colour management off, or rasterizing the file in Corel. I believe there is an option in the print window.
Have you tried making a PDF of the file and printing that?
Using the ICC profile could be a solution, but the Fiery is what is needed.
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
162 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
