Question about Eclipse Premium 34230 Car Audio Amplifier
Volume button wont work only to lower volume works
It works when you lower volume but it doesnt work when you try to higher volume
    Problem Solver:
  • 5 Answers
Are you talking about the Amp working in lower volumes or the cd player? If it is the amp do you have the speakers bridged.
Posted on Mar 06, 2009
The volume is not responding from either the remote or the console; mute function not working either.
Check your remote control to see if the buttons are working properly. Or go into your unit's settings and check what the volume default is set to - It might be set to prevent it from going lower or higher.
Sep 13, 2014 | Bose 321GS Series II System
Volume button problems
You must remove the radio and have it repaired by an authorized factory repair center.
Apr 01, 2014 | 2003 Acura RSX
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
Dec 12, 2012 | Sharp 32U-S610 32" TV
Mobile phone nokia c7 speaker goes loud at one time and then you dont hear anything. why?
Possible that the speakers are faulty or the circuit in the mother board is faulty.
Try and lower the volume level and see if the speakers work without failing , if so the speakers can be faulty.
Also try with a headphone , if there is no fault with higher volume then the circuit seems faulty.
Apr 15, 2011 | Nokia C7 (8 GB) Smartphone
I lowered the volume on the ASUS monitor...how do I get it back up (higher)..The monitor button only lowers the volume....
Hold down the volume and Brightness/UP buttons down at same time to adjust level higher)
Mar 30, 2011 | ASUS LCD Monitor
One channel muted until the volume is turned up
This problem is usually dur to some corrosion in the speaker relay. If the relay can be opened, burnish the contacts and you should be OK. The higher volume creates a higher voltage that can "jump the gap" so to speak. Once the connection is made it will remain. That is why lowering the volume will work.
Dan
Apr 14, 2010 | Yamaha AX-396 Amplifier
Receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Mar 30, 2010 | Audio Players & Recorders
They are makeing a constant sharp noise a loud high pitched hum if you will
Right-click on the speaker icon in the lower right of your screen and choose Open Volume Control and check all volume levels (make sure they are not set to high). If this doesnt work then when you right-click, choose Adjust Audio Properties and search around for volume controls (maybe try the Speaker Volume button).
Aug 04, 2009 | Audio Players & Recorders
Receiver won't let volume go higher than -7 dB
Actually, -7 db and above woul be quite load.
Anyway, I am not very familar with the Pioneer GUI auto setup. But, am aware of how AVR are set-up.
If you have set up the home theatre by auto/manual setup then please check the channel levels whether any of your channels settings is at +7.0db.
If so, reduce this setting where it more +7.0, then you would be able to raise the overall main setting from the volume control to go higher than -7db.( by as much as you've lowered the particular channel setting)
Please do let me know if this helps.
Apr 29, 2009 | Pioneer VSX-1018AH-K Receiver
HOW CAN I RESET THE V CHIP TO UNBLOCK ALL THE RATINGS
Try this procudure from the manual.
Notes (for TV RATING and MPAA RATING):
● You cannot access the setup menu when the
“PROTECTED PROGRAM by ...” message
appears. Move to an unblocked channel
before you hit [MENU].
● When you select a rating and set it to
[BLOCK], the higher ratings will be blocked
automatically. The lower ratings will be
available for viewing.
● When you set the lowest rating to [VIEW],
all other ratings will automatically be available
for viewing.
V-CHIP SET UP
MENU
To exit the menu
[CHANGING THE
Oct 04, 2008 | Durabrand DWT2405 24" TV
Eclipse Premium 34230 Car Audio Amplifier Logo
162 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
