Question about Jabra BT125 Headset
Jabra BT125 bluetooth will not pair with replacement phone I recieved Motorola Krazer. No devices in history and 3 minute detection times out.
  • Anonymous Mar 26, 2009
    I have the same problem but my new phone is a motoroyla roker
  • bllaco69 Apr 03, 2009
    i have the same problem with my motorola i335 & my instinct
Lost password
Posted on Mar 14, 2009
    Problem Solver:
  • 5 Answers
Try turning it off then on and hold on power button<on blue tooth while the phone is searching for headset. my krazer had the same problem with my bluetooth..
Posted on Mar 06, 2009
  • hooprides Mar 06, 2009
    I assume it didn't work
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
I cant do pairing my jabra bluetooth head set to dopod
Turn on your BT125 by presiing button for 4-5 secs
in ur dopod go to settings>communication>blutooth
In the mode tab:check on > turn on bluetooth and >make device visible to others
Then go to devices tab: click on add new devices, your dopod will start searching nereby bluetooth devices...during this time press the button on your BT125 for about 2 secs, it will try to connect to dopod and a message will be displayed : "BT125 wants to connects......" say yes ...it will ask for the passkey enetr 0000 and there you go ...tada
Jun 26, 2009 | Jabra BT125 Headset
I lost the instructions. I want to pair my Jabra bt125 with my motorola razr
1. I have the Jabra 125. You can get the manual at www.jabra.com if you have a different one.
2. Turn off your phone. Power off. The order of powering on devices is the key.
3. Press and hold your Jabra power button until it's glowing blue (not flashing blue light--but constantly on)
4. Then turn on your phone...and look for wireless devices in your phone menu.
5. Make sure you have bluetooth turned on.
6. the phone will find the Jabra, and then will ask to pair with it. passcode is 0000.
7. That's it.
Again, the key is the order of turning on devices.
Thanks.
Jun 05, 2009 | Jabra BT125 Headset
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
Registering and pairing with the ps3
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
If it asks for a password it's "0000"
Mar 23, 2008 | Jabra BT125 Headset
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Feb 21, 2008 | Jabra BT125 Headset
Connects but won't pair
to connection to your phone or device
turn off your jabra then press and hold the big white button until the light stay on the search for your device
Dec 25, 2007 | Jabra BT125 Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra BT125 Headset Logo
248 people viewed this question
Top Jabra Radio Communications Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
vimal
vimal
Ed Nelson
Ed Nelson
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
