Question about Toshiba Satellite L25-S119 Notebook
How to restore factory settings
Restore factory settings can't get on the internet
  • marshall114 May 10, 2009
    I have a Toshiba L-25-S119 and i trying to do a system restore because i have a virsus. i have the system restore cd but it not picking up on my computer. How can I start the system restore as my computer is coming on..
  • Anonymous Mar 19, 2014
    I have tried to restore, but won't let me and cant even find the help and support
  • 741 Answers
Best bet is to do a system restore to a date before you have problems. Go into start>accessories>system tools>system restore. Your computer automatically creates restore points each time you log on..so once you are in system restore just pick a date that was before you had problems and your system will restore itself to that date...if you have any questions let me know..there are other options if that does not work so keep me updated..
Please rate with 4 diamonds.
Posted on Mar 06, 2009
Reset HP 226dw
estore the factory-set defaults
Restoring the factory-set defaults returns all of the product and network settings to the factory defaults. It
will not reset the page count, tray size, or language. To restore the product to the factory-default settings,
follow these steps.
CAUTION: Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also
deletes any pages that are stored in the memory.
1. On the product control panel, press or touch the Setup
Open the
Service menu. button. 2. 3. Select the Restore Defaults option, and then press or touch the OK button.
The product automatically restarts.
Jan 11, 2018 | HP Computers & Internet
How to reset clock on 6520 mpbile
Follow the instructions on the screen to set up your phone and prepare it for use.
  1. Find "Reset all" Press the Navigation key. Select Settings. Select Security. ...
  2. Restore factory default settings. Key in the phone lock code (default is 1234) and press the Navigation key. Press the Navigation key to confirm.
Doro 6520 - Restore factory default settings - Device Guides
https://userguide.vodafone.co.nz/doro/6520...os/basic.../restore-factory-default-settings/.
or go to this link might help.
How to reset clock on 6520 mobile Google Search
Oct 28, 2017 | Computers & Internet
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
Code entered to restore the factory settings is does not match.
Go to Settings>Restore Factory Settings
The default security code is 12345 you go to internet browser settings then restore factor code s 12345
or
one of this code *#7370#
Feb 17, 2011 | Nokia 3120 Cellular Phone
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
Dec 17, 2010 | NetGear WNR2000 Wireless Router
I formatted my C drive because I couldn't get it to do a system restore back to factory settings. I had to install Windows 7 from a USB drive. The install went fine, but now that it's running again, I'm...
Too late - when you formatted the entire drive you erased all partitions including the restore software that was initially included with your machine. If you cannot connect to the internet now it is because you have driver issues. Using device manager find the peripherals that have exclamation marks or questions next to them and use another computer go into the web and look for win 7 drivers for them.
Good luck
Aug 27, 2017 | ASUS Eee PC 1201N (1201NPU17SL) Netbook
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Wireless internet is not working after restoring factory settings
Oh, wireless Internet? You restored it? Did you install a different operating system? Or had you installed one before resetting? A change of OS may result in the deletion of particular drivers.
Go to the manufacturer's website. There, search for your model's support and download the drivers you want, for instance, the wireless network adapter drivers. Also, check your sound.
Jan 30, 2009 | IBM ThinkPad R40 2722 Notebook
Toshiba Satellite L25-S119 Notebook Logo
1,075 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
