Question about Intermec CK31 Portable Terminal
My Intermec CK31 just hangs, it scan and there is a sounf beeping but the touchscreen is not working and even the keyboard.
    Novelist:
  • 75 Answers
The fact that you cant get to the factore restore options as the touchscreen and keyboard are faulty you might as well first try a reflash of the operating system. (I personally dont think that will help, but what have you got to loose).
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also note that there are usually 2 versions EX25 and non-EX25 scan engine type.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 11, 2009
  • 61 Answers
Sounds like you could have a main logic board problem. Try restoring computer to factory defaults from the intermec settings.
Posted on Apr 05, 2009
Can't connect CK31 to Barcode software
Hi Chris,
You need a few things to be able to connect your Intermec CK31 to a server and all the settings are within the "Intermec Settings" within the terminals control panel.
First thing to start with is the wireless profile, set this up to match your current access point wireless settings, SSID, Encryption Type, Key etc. You can also set your wireless IP. Once this is done there will be an icon in the taskbar that shows connection and signal strength. Depending on the firmware revision of the terminal you should be able to use the tools to ping a device on your network, if the server responds to a ping then you should be able to get to your server when you try and connect.
I hope this helps.
helpdesk@biastechnology.com or TEL +44(0)1202 620955
Jun 19, 2012 | Intermec CK31C,COLOR TE2000,5KY LINR
Scanner reads some barcodes (black and white, larger barcodes), but not smaller barcodes that are black w/gold background.
Acutually, some kind of conbinations of bar color and background color will prevent barcode readers from accurate scanning. So I think you should check whether your color combination is feasible first.
I want to attach an image, but it is too big to upload.
Feb 08, 2011 | Intermec CK31 Barcode Scanner
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
Intermec CK31 the most slow terminal.. is a piece of ****..
We have come across this many many times. After the terminal has fully booted (can take an hour when slow) and if you manage to access the CPU monitor you would be able to see that the CPU is running constantly at 100% - not good.
A complete blank and operating system restore is required.
or TEL 01202 620955
Nov 07, 2009 | Intermec CK31
2 of the slots don't hold battery in place to charge
Return it to the manufacturer for a refund, or a replacement.
Jul 29, 2009 | Intermec 4-Slot Battery Charger for CK30...
How do you put Caps lock on?
Click here, or copy and paste in your browser. It will take you to the manual and you can print it out.
Good Luck.
http://www.intermec.ch/handbuch/CK31_Handbuch.pdf
Apr 09, 2009 | Intermec CK31 Barcode Scanner
Ck31
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Sep 07, 2008 | Intermec CK31 Portable Terminal
Intermec CK31 handheld - Configure to read bracket symbol
Mar 10, 2008 | Intermec CK31 Portable Terminal
Intermec CK31 Portable Terminal Logo
893 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
