Question about Epson ACULASER CX11NF All-In-One Printer
Blue toner is printing on the paper. I have a spill in the print
I have a blue toner spill. how do I clean it up in the machine?
Thank you
    Problem Solver:
  • 16 Answers
Be careful with the developer rods which are coverd with toner the rest you can pick using vacume cleaner with soft brushing.
  • remove the cartrides
  • remove photoconductor unit
  • avoiding the developer unit RODS which are 4 in total and are next to each cartridge chute with toner powder on them.they are charged rod and thats why tonner is attracted to them as toner powder is also charged.
  • I did this myself and it works fine.
Just do it when you are relaxed and remove any part which you can remove n then vacume the spilled toner.
Posted on Mar 11, 2009
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8220 leaving ink on printed docs. How do you clean that?
That's usually a bad toner cartridge that dumps too much toner per print. Buying a new toner cartridge should fix it. You may need to wipe up a little spilled toner inside. Just use a dry cloth, and be very careful around the little black levers that stick up to detect the paper.
There are other manufacturers who sell toner for these, but some of them have toner inside that's so hard to stir, it breaks the gear in the machine. That makes a very expensive repair for the little money you save on generic toner.
Dec 03, 2010 | Brother MFC-8220 Fax
Why does my samsung scx5530fn printer constantly prints blank sheets of paper...we have turned it off/on; changed toner and it just decides to starting printing blank pages..anybody can help me i thank...
Please clean the drum and the fuser, also check the toner cartridges if there's any overflown toner powder spilled. The problem is caused when the toner waste tank in the drum is full or overflowing.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
Black prints 1" either side of page. middle fades to nothing.
clean the paper path rollers. usually if toner cartridges are refilled type they are overfull and spill toner on paper path.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Ricoh Aficio CL3500N Laser Printer
Large lines of ink through paper when printing
check drum for sign of line, if not found proceed to fuser for a sign of toner spill. for where ever spill found clean and make a test print again. if found again remove toner and check for possible spillage path for the repair or replacement.
Apr 15, 2010 | Dell 3010cn Laser Printer
Printing a blue streak
your ink have been spoiled re-install the cadrige that you can print
Jul 11, 2009 | Samsung CLP 300 Laser Printer
Can send faxes they can read fine but when i get faxes cant read them about a week ago paper jamed in the roller do i need to clean with what product
I assume you talking about a panasonic DP-190? Do not clean the drum you may gently wipe it down, realize the drum puts the image on the paper, nick it, grease from hands, ,etc will effect copy qualilty. Remove the toner cart. clean any toner spilled. Drum may need replacement, print a toner/drum resupply form to see if the machine prints them cleanly
May 08, 2009 | Office Equipment & Supplies
HP laserjet 2600n
You are spilling blue toner. Try to vacuum out the excess blue toner from the machine. Be careful not to scratch the transfer belt.
Dec 13, 2007 | HP Color LaserJet 2600n Printer
Print
Cleaning a laser printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Clean your printer when print quality deteriorates or when you change toner cartridges. Manually Cleaning Inside the Printer Steps: 1. Unplug the printer from the surge suppressor. 2. Remove the internal paper trays. 3. Remove the toner cartridge and place it on a piece of scrap paper. 4. Clean inside the toner cavity with a dry, lint-free cloth and brush (if a brush is supplied with the printer). 5. Clean the printer mirror gently with the brush. Don't touch the mirror if a brush isn't provided. 6. Wipe away dust and spilled toner. Remove paper fragments. 7. Clean the rollers, but don't touch the sponge roller. 8. Replace the toner cartridge. Tips: To remove unfused toner from the rollers following a paper jam, print 5 to 10 blank pages on scrap paper. Wipe toner from clothing if necessary, then immediately wash toner-soiled clothes in cold water. Go to your printer manufacturer's Web site (see Related Sites) for detailed cleaning instructions. Warnings: Don't use any liquid cleaners inside the printer. Initiating Automatic Cleaning Through Printer Software Steps: 1. Open the printer software by double-clicking on a printer icon or specific printer utility program, or opening a document and then selecting Print from the File menu. 2. In the printer software, look for a button labeled Options, Troubleshooting, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.) 3. Follow the instructions on the screen. 4. Repeat the cleaning process if the results aren't satisfactory.
Jan 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
Epson ACULASER CX11NF All-In-One Printer Logo
224 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
