Question about Cosco Juvenile Scenera® 22160 Convertible Car Seat - Rising Tide
Need instructions to install Zuzu car seat. How to tighten straps around seat when in rear facing position.
5 Suggested Answers
  • 126 Answers
SOURCE: eddie bauer rear/front facing manual
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s why a downloadable version of many of our instruction manuals are available right here online. Simply fill out the form below and click Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Posted on Apr 24, 2008
  • 5 Answers
SOURCE: I need to know how to position the straps for rear facing car seat
Here's the official manual:
http://www.babyage.com/icons/localhost/products/multimedia/26078_3591328.pdf
Posted on Jul 25, 2009
MrsK87
  • 43 Answers
SOURCE: how am i supposed to get my child in the car seat
The belt should run under the car seat not over it or on the sides. Take the car seat to an inspection station and have them install it properly. www.seatcheck.org
Posted on Apr 21, 2011
  • 25 Answers
SOURCE: need new tether strap hook
Contact Evenflo's Parentlink Resource Center - contact info here. They can help you.
Posted on Feb 18, 2009
SOURCE: Latch belt too short
Looked at the owner's manual of my car and realized where I needed to hook the latch belt hook strap. I was trying to hook it to the wrong thing. Car seat works great now!
Posted on Nov 23, 2009
Combi instruction
It depends on your car seat. Follow your instruction manual for your child seat and your car. Not all seating positions have tether anchors.
"Rear-facing only" seats do not tether (these have a separate base and carrier)
"Rear-facing convertible" seats may tether.
"Forward-facing" seats usually tether (some MUST tether).
Jul 19, 2014 | Eddie Bauer Baby Gear
How do you remove the starter on a 03 Harley Davidson Dyna Low Rider?
Instructions
  1. Removal
    • 1 Remove the seat retainer screw from the seat mounting bracket using a ratchet and Allen driver. Lift the rear of the seat up and slide the seat toward the rear of the bike to disengage the seat from the frame and remove it from the bike.
    • 2 Don a face shield and rubber gloves.
    • 3 Remove the battery cover retaining screw from the bottom of the battery cover using a ratchet and Allen driver. Tilt the top of the battery cover out and lift the cover to disengage it from the battery tray.
    • 4 Remove the negative battery cable from the battery using a 10 mm wrench.
    • 5 Remove the positive battery cable from the battery using a 10 mm wrench.
    • 6 Unhook and remove the battery strap. Remove the battery from the tray. Remove face shield and rubber gloves.
    • 7 Remove the two top battery tray screws from the frame above the battery tray and the bottom battery tray screw from the inside of the battery tray using a ratchet and Allen driver.
    • 8 Remove the battery tray from the bike while guiding the battery cables through the holes in the battery tray.
    • 9 Remove the starter end-cover nut, using a ratchet and socket, and pull the end-cover off the starter.
    • 10 Pull back the protective rubber boot off the positive cable terminal. Using a wrench, remove the positive cable nut and then lift the ring terminal off the starter terminal stud. Unplug the solenoid electrical connector from the solenoid.
    • 11 Remove the two starter retaining bolts from the starter using a ratchet and Allen driver. Pull the starter off the bike. Remove and discard the starter housing O-ring.
    Installation
    • 12 Inspect the two split-ring bushings in the inner primary case where the starter mounts for slack or looseness. Remove the split-ring bushings and spread them to provide a slight interference fit in the primary housing. Push the split-ring bearings back into position.
    • 13 Install a new starter housing O-ring on the starter assembly. Install the starter assembly on the bike.
    • 14 Apply one drop of Loctite Threadlocker 243 to the treads of the starter retaining bolts. Install the starter retaining bolts and washers and tighten them to 24 to 27 foot-pounds using a foot-pound torque wrench and Allen driver.
    • 15 Install the positive cable ring terminal and nut on the starter terminal stud. Tighten the nut to 65 to 85 inch-pounds using an inch-pound torque wrench and socket. Push the protective boot securely over the positive cable terminal. Plug the solenoid electrical connector into the solenoid.
    • 16 Position the starter end-cover on the starter and install the nut, using a ratchet and socket.
    • 17 Place the battery tray in position while guiding the battery cables through the holes in the tray.
    • 18 Install the upper and lower battery tray screws and washers. Tighten the screws to 96 to 120 inch-pounds, using an inch-pound torque wrench and Allen driver.
    • 19 Guide the battery cables into the recesses at the upper corners of the battery tray.
    • 20 Don face shield and rubber gloves.
    • 21 Place the battery in the battery tray with the terminals facing out. Snap the battery strap in position.
    • 22 Install the positive battery cable and cable bolt. Tighten the bolt to 60 to 70 inch-pounds using an inch-pound torque wrench and socket.
    • 23 Install the negative battery cable and cable bolt. Tighten the bolt to 60 to 70 inch-pounds, using an inch-pound torque wrench and socket.
    • 24 Remove the face shield and rubber gloves.
    • 25 Apply a light coat of corrosion retardant grease or petroleum jelly to the terminals.
    • 26 Install the battery cover and screw. Tighten the screw securely using a ratchet and Allen driver.
    • 27 Place the seat on the bike. Lift the rear of the seat and slide it forward to engage the seat tab in the frame slot. Lower the rear of the seat and install the seat retainer screw through the seat mounting bracket. Tighten the seat retainer screw securely using a ratchet and Allen driver. Lift up on the seat to make certain that it is mounted securely on the bike.
Jul 08, 2012 | 2003 Harley Davidson FXDL Dyna Low Rider
How to remove starter from 2008 dyna lox rider . I have already un bolted it and removed wires but it is loose but will not come out yet .
Instructions
  1. Removal
    Installation
Nov 18, 2011 | 2008 Harley Davidson FXDL Dyna Low Rider
How am i supposed to get my child in the car seat when in the rear facing position the seat belt straps are around the sides of the car seat
Apr 21, 2011 | Britax Marathon Convertible Car Seat ...
How do you install and know if its reclined. my son seems to be sitting too upright, he is only 6 months but already 21 pounds. he is appropriate weight wise. I have a 2006 explorer.
u could use the safety straps on the back. or you could run the seatbelt through the holes at the bottom of the car seat. check your users manual from your explorer to see where the safety hooks are. http://www.eddiebauer.djgusa.com/usa/eng/Instructions?ProductNumber=22790WPR
Jan 13, 2010 | Eddie Bauer 3-In-1 with Latch
How to loosen the straps on envenflo tribute carseat?
This is about all I could find for you. Hope it helps.
Had one - its a huge pain in the **** and I always busted my fingernails doing it. The metal clips have to slide over the bumps to get them out. I hated that thing. May I make a suggestion? Return it. lol . I'm figuring you got a combo seat - Evenflo Generations, Bolero, Chase, that is a forward facing only seat to 40lbs, or a convertible seat like Evenflo Tribute that is forward facing to 40lbs. Since I don't know her age its hard to make a suggestion, but for just a little more money (we paid $79 for our Chase) you could get a much better seat. If she needs a convertible that will rear face, get the Evenflo Triumph for $150 or less, The Evenflo Triumph Advance (not the original Triumph, make sure it says Advance) is a great seat. $150 version at Babies R Us has padding similar to Britax seats, top slots of 17", harnesses to 35lbs rear facing, and 50lbs forward facing. $120 Walmart version just has little less plush padding. Wide open belt path, easy to install, though it doesn't have built in lockoffs. The harness adjusts at the front of the car seat, you don't have to take the car seat out of the car just to raise/lower the straps. It's one of only 2 seats that does this (The Britax Boulevard is the other, I believE), and it has infinite harness adjustment so the harness always fits perfectly until its outgrown. No more tugging straps to tighten them either. You tighten and loosen the harness using knobs on the side of the seat. As a major bonus, it can be used in a recline position even in forward facing mode. Awesome for kids who still sleep in the car. I LOVE THIS SEAT! LOL My son, who is too big for every other car seat at Walmart has the same amount of room in this as the Britax Marathon.
If she is forward facing (over 30lbs and over 2years old) then a Graco Nautilus would be a lot easier to use and install, $150. Harnesses to 65lbs and then becomes a booster, will be the last seat you have to buy her. Metal reinforced.
Combo seats are usually a major waste of money, as they only harness to 40lbs, no more than most convertible car seats, so you're really not getting any more use out them then the convertible seat.
Jun 12, 2009 | Evenflo Generations
Nov 02, 2008 | Evenflo Comfort Touch Vanguard 5
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Cosco Juvenile Scenera® 22160 Convertible Car Seat - Rising Tide Logo
949 people viewed this question
Top Cosco Juvenile Baby Gear Experts
Iron
Iron
Dorel UK
Dorel UK
Tom Chichester
Are you a Cosco Juvenile Baby Gear Expert? Answer questions, earn points and help others
