Question about GALAXY Microsystems 63702 Top Freezer Refrigerator
The compressor runs all the time and the freezer only gets to 30 and the fridge only gets to 50 could i have a pluged dryer? i bought it used but not for sure if it has ever been layed on its side.
  • Jill_Fitzger Mar 23, 2009
    My fridge temp. won't go below 50 but my freezer works fine.
  • 400 Answers
It sounds like the fridge is short of refrigerant.
Posted on Mar 06, 2009
Freezer side and fridge side not working, temps are freezer 30 fridge 50
Most likely the condenser coil is dirty. It is under the fridge, clean it with a vacuum, or air pressure, blow it out outside it will ne dusty . There are two to three fans. One by the compressor, called a condenser fan. If it is a side by side, usually there is a fan in the freezer section, and one in the refrigerator section. All need to work. If all this is and the compressor is running then chances are the compressor has bad valves. Make sure there is no ice on the coils in the refrigerator and freezer coils. If there is ice you have a defrost problem, which can be fixed. If the compressor has bad valves, get a new refrigerator.
May 08, 2014 | Maytag MSD2454G Side by Side Refrigerator
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Model # msd2756de freezer and fridge stopped cooling, Christmas Day!!!!!!! unloaded freezer, fridge overnight the temp the next morning is 15 in freezer and 50 in fridge. moved thermostat back and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Maytag Refrigerators
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 26, 2010 | Dometic RM2652 Refrigerator
Just bought a new whirlpool top freezer fridge. Waited 4 hours then plugged it in. 30 hours later food is still not cold enough and fridge continues to run. Will it get colder, am I not giving it enough...
If you transported the fridge on it's side you may have drained oil into your lines, causing excessive head pressure. If you haven't unplugged it yet, please do it now and allow 8 hours for the oil to drain back to the compressor. If you are lucky, and the fridge didn't run too long and burn up the compressor, you should be able to come up to temperature with no trouble.
Mar 09, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My 685 freezer is fine, but the fridge is only getting upto 50
Check the compressor fan motor. Is it running?
Check the freezer and Fresh food fan motors. Arte they running?
Jan 04, 2010 | Sub-Zero 685/S Stainless Steel Side by...
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
Fridge Not Getting Cold
The only thing i can thing of is the start switch it may be burned out.It is located on the compressor.If your compressors running and there is no cold air in freezer part and fridge you may have a sealed system leak.Open the rear bottom panel while the fan is running and feel the compressor if it is hot and it is running you may need a repair person to come look at it.also forgot to say is if you have frost bult up in rear freezer panel that would indicate it is froze up and will need a manual defrost .After done that the defrost timer may need replaceing it is locatedaround the control and light area.hope i fixya :)
May 22, 2009 | Frigidaire FRT21P5A Top Freezer...
Fridge freezer not reaching operating temperature
maybe its time your fridge to go to the service center. 5 years is a long time yaknow. have them check for the freon as it might have runned out.
Jan 14, 2008 | Candy CPCA240FFK Bottom Freezer...
RUNS A LONG TIME
Check if the capillary tubes is really bend and can restrict the flow of refrigerant. Restriction in the system can cause the trip off of the compressor overload. Please call qualified technician to correct the problem.
Dec 27, 2007 | Frigidaire Freezer GLRT183TD
GALAXY Microsystems 63702 Top Freezer Refrigerator Logo
125 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
