Question about Philips Magnavox 42MF521D/37 Television
The sound on my TV will just stop i have to turn it off and then back on to get it to work
  • mikejerky Mar 19, 2009
    same problem but now no sound at all
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Sanyo tv sound has stopped working when dropped on floor??
Check and replace its audio output card. There might have some crack in the circuit board.
Aug 20, 2012 | Sanyo Televison & Video
Xbox 360 sound stop working
It took me a long time to figure out but all I had to do is turn my TV all the way off and back on then it was fine.
May 01, 2008 | Microsoft Xbox 360 Console
SOUND JUST STOPS AT ODD TIMES
first, change the speaker. second try to adjust the sound IF trnsformer, third resolder the amplifier IC.
Mar 29, 2008 | Samsung SlimFit TX-S2783 TV
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
Philips Magnavox 42MF521D/37 Television Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
