Question about ASUS P5VDC-MX Motherboard
1gb shows 512mb only
I have p5vdc-mx motherboard with 512mb rddr2 ram but when i add 1gb ram then it only show 960mb ram,
i will apply 1gb ram alone in motherboard but it only show 480mb ram.
the ram will be same specification please help i dont understand what is the problem on my motherboard my computer specification is-
asus p5vdc-mx 1.x/2.x
bios version 0712, date 11/01/2006
intel pentium 4, 2.66 ghz, 533mhz, 1mb
ram-
slot1-512mb,667mhz
slot2-1024mb,667mhz
  • pornsak_k Apr 19, 2009
    I have same problem. I have install 512MB DDR2 and 1 GB DDR2 but BIOS shows usable RAM 1GB. Then I remove all of them and install 1GB only, BIOS show 512 MB. Please advise.
  • Anonymous Apr 28, 2009
    I have two DDR 1 gig sticks and my computer is only reading one gig. I took them out, tested them and they both work fine. Is my motherboard only reading one side of the sticks?
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Posted on Mar 13, 2009
    President:
  • 1,179 Answers
The motherboard is only reading one side of your DDR2 RAM. In other words it is reading it as DDR not DDR2. You can check your bios settings and if it still is reading only one side then your mb may not support double sided RAM. If you just bought this you should be able to return it & exchange for a one sided 1 gb DDR2 stick. The other thing you could try is instead of mixing the chips try adding a matched 1 GB stick and see if the mb reads it as 2 GB installed. You should always install RAM in pairs to avoid problems, most boards recommend matched pairs. Hope this helps & please take a moment to rate this solution. Thanks.
Posted on Mar 06, 2009
P5vdc-mx ram displaying 1gb, instead of 2gb in single slot DDR2. FSB 533 MHz, RAM - transcend
Remove the memory card in the motherboard and then clean the pins of the memory card by an eraser of a pencil and then plug it again. Start the computer and see if it works.
Nov 07, 2009 | ASUS P5VDC-MX Motherboard
Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
post a coment if this does not work.
thanks,
wonder
Sep 18, 2009 | ASUS P5VDC-MX Motherboard
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
ASUS P5VDC-MX Motherboard Logo
1,921 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
