Question about Frigidaire Affinity ATF7000E Front Load Washer
Front load washer motor just buzz and turns of braker.It is a brand new unit,was installed yesterday.
  • 360 Answers
This is a warranty issue.....Contact the retailer. Do not attempt any repairs for it will void your warranty.
Posted on Mar 06, 2009
Kenmore front load washer won't spin
May be the enginer have gone bad ,you can check if there is something wrong .
Feb 25, 2013 | Washing Machines
My Kenmore HE3 front load washer has code F 11 it's stuck there since yesterday, and the door wont open. How can I unlock the door. All my work clothes are in there, and I am afraid they will get...
Here is what Kenmore says.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
May 17, 2011 | Kenmore 42822 Front Load Washer
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
My washer filled up and didnt and stopped. Reset by unplugging for 30 seconds and in now making a buzzing/humming sound but not moving still.
I am sure this is not what you want to hear but is sounds as if your washing machine motor is not turning hence your hearing the unit attempt to start and the armature is locked, Make sure the unit is unplugged reach underneath the front left side of the bottom of your washer and push the pully toward the cent of your washer at a 45 deg pushing point. The motor assy is supposed to glide. If it glides the try rotating the motor by hand. If the motor rotates reach to the lower rt side of your unit and try to rotate the pump by hand. If this rotates freely attempt to restart your unit again. I would like to know the results at this point before going any further. .
Jan 05, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
I have a neptune washer that makes a buzzing type noise when I hit the start button? from motor area. The belt and pulley into the unit turns freely. I did get it to start and the barrel did rotate then...
The buzzing noise is probably an electrical relay that controls the motor. They have a spring assembly on an arm. When you energize it it creates a magnetic field and pull the arm down into contact and starts the current flow to the motor. If it's buzzing, the relay is probably bad and need replaced.
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Duet washer deliv yesterday start button won't work.
delivered yesterday??? call back the dealer and have them send out a repairman/ or replace the unit you didnt pay for a brand new unit to be reapired
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
AFT 6700 - Brand new unit just dropped off code 31 in the display.
The problem with attempting repair on a new machine is that it can void the warranty. I'm sorry. You must be frustrated.
Jul 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
