Question about Canon ZR50MC Mini DV Digital Camcorder
Canon zr50 mc, door to tape compartment will not close
I have a canon zr50 mc, and the door to the DV tape compartment is stuck open. It normally will close automatically once a tape is inserted. It is frozen there. I tried to lightly "encourage" it to close, but will not budge. It was used maybe one year lightly, but this happened and it's been in the box in storage for years. Going on a ski vacation and need a video cam, and don't want to spend $500+. Thanks
SOURCE: Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Posted on Mar 24, 2008
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
Hi guys,
Thank you very much for this solution posting. Really it worked. I was about to buy another one instead of fixing the problem. Because you know how the pain is, to send it factory and getting it repaired.
Once again Thank you.
Posted on Jun 26, 2008
SOURCE: Mini DV tapes transfer to computer
wow, i have the same exact problem. im using a canon too. and i dont have an installation CD or anything, because i baught my camera at a pawn shop. the only thing i can think of is that i might be using the wrong type of fire wire cord? do i need to use a DV fire wire cord? i have no clue.
Posted on Aug 21, 2008
old marine
  • 2016 Answers
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
Tape in question - "wheels"
Sorry, but you are going to have to describe the problem if you want an intelligent response. What do you mean by 'wheels'?
Oct 11, 2017 | TDK DVM60 Mini DV Tape
Canon ZR300 Mini DV Digital Camcorder THE MINI DV TAPE IT DOES NOT GO INSIDE THE CAMERA, SOUND LIKE IS GOING BUT IS EJECTED WITH A AUDIO WARNING AND IN THE VIEWFINDER SAY REMOVE THE TAPE AND A X APPEARS,...
I know this is going to sound strange. I had the same issue with my ZR300. When you insert a tape and close the mechinism you hear the tape whirl then it pops open and chimes. I found a solution online and thought it was to good to be true. It said to hold the camcorder in your left hand with the right side up (the opposite side of the fold out viewer). You then hit the camcorder , not real hard like slapping something. Open the door and insert the tape and WHAM! It loaded fine. Eight people had tried it according to the review and all eight people had success. I was skeptical but it works! Don't hit it so hard you break it. I did mine twice before it worked but it works everytime now. Trust me just try it and it will work.
Nov 03, 2010 | Canon ZR300 Mini DV Digital Camcorder
Tape transport stuck in open position. Will not take tape into unit.
It could be possible that the tape is in the wrong way or that the tape is the wrong size those are both reasons that it may not be closing
May 25, 2009 | Canon ZR70MC Mini DV Digital Camcorder
My canon zr850 is rejecting mini dv tapes what do i do?
Sometimes this is caused by the tape itself, or more specifically, the tape case. If the tapes are labeled, there is a chance that the flap which lifts to expose the tape is stuck closed. Check this by locating just bellow the flap on the tape a recessed button. Press and hold it while opening the flap. If it's sticky, or stuck and is difficult to open, this is your problem. Make sure the flap opens unrestricted by removing the labels from the case which would hinder this motion. Hope this helps.
May 04, 2009 | Canon ZR850 Mini DV Digital Camcorder
ZR25MC, DV tape can't be ejected.
The best way to get it out is take it to a camera shop of Best Buy. They didn't put a manual eject on the player. If you take it into a shop they should know what to do.
Once it's out clean the heads with a DV tape cleaner.
Jul 13, 2008 | Canon ZR25MC Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon E520 camcorder
the head needs aligned.. the cassette compartment is out of balence
Feb 28, 2008 | Canon ZR80 Mini DV Digital Camcorder
Canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
Sep 09, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon ZR50MC Mini DV Digital Camcorder Logo
64 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
