Question about HP Pavilion dv9000z Notebook
Hp 9720us note book has black screen. if I connect another montior it works fine, everything runs fine. Hp says it might be something to do with wireless.? This is my third laptop with problems in 15months I am two days out of warranty and HP refuses to help. I've sent it to a local shop but he cannot find any fix for it ? could this be a firmware problem ?
  • jmattioli Mar 06, 2009
    thank you I will pass on that information.
    Problem Solver:
  • 15 Answers
You should try updating the BIOS. You can find the latest BIOS on To find the correct modell search for the modelnummber. You can find it under the unit on a white lable. It will look something like this AA111BB#CCC. Then go to software and drivers downloads and chose operating system. You should find the latest BIOS somwhere on the page.
If this doesnt help it is either a defective mainboard or LCD panel. So the unit will need service unless you can change the parts yourself.
Posted on Mar 06, 2009
  • HP Master
  • 32,281 Answers
Can you see a slight image?
As you can see an image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
  • 271 Answers
This problem is the Display...everything is good.
Please don't forget to rate me "FIXYA"...thank you!
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
I have a fine horizontal line running 2/3rd's of my hp mini note book.should i be concerned?
This could be a hardware issue with the LCD screen of display card. To confirm the same, connect an external monitor and check if the same line appears on external monitor. If external mitor works fine, then its a LCD defect. If you have same issue on both LCD and External monitor, then it could be due to display card. In either cases you may need to take to service center.
May 22, 2010 | HP Mini 1000 Netbook
Black screen even if switched on
the note book is not booting or you have a problem with your screen just try to connect it with another screen to see if the problem is in the screnn or it is dead
Oct 25, 2009 | HP 2133 Mini-Note PC KS106UTABA$266...
Black screen
Black screens are never good. Usually indicating a hardware failure. You can try a top down troubleshooting method I will give you here or you can send it to the experts to fix. First remove memory and see if you hear any beeps also try replacing with new(reinstall if none). Remove hard drive as well. Now if still nothing will show then you can narrow it down to the motherboard/processor/cmos battery. I would suggest ordering a new battery first and then motherboard- try using your old processor chip on the new motherboard.
Sep 22, 2009 | Acer Aspire One PC Notebook
HP Pavilion laptop screen has gone black/blank
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
Jun 22, 2009 | HP Pavilion dv6835nr Notebook
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My pioneer dvr-k17b ata device does not work. ie CDs do not work on my system, which is a Vistas HP Pavillion dv6500
I have the HP Pavilion 9720us laptop, with a Pioneer dvr-k17b dvr. It is not recognizing any CD of DVD. What could be the problem. I have the latest drive update
Jun 08, 2009 | Pioneer DVR-107D DVD±RW Burner
I have trouble of my desplay, power work ok but can not display any thing
hey. there is a inverter in LCD that makes view brightly shinely so you can see everything on LCD. anyway. if the inverter breaks down you get black screen. even inverter is working you get blanc screen you need to check LCD DATA CABLE that it not possible to reach it for you. i advise you to get the Service if you have warranty
have a good day.
pls rate this.
May 28, 2009 | HP Compaq Evo n620c Notebook
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Mar 10, 2009 | HP Pavilion DV9720US Notebook
Screen not working
It could be that the connection to the screen has loosened up for some reason. If the warranty is void you can try to open it up (if you're up to it), taking the bottoms screws out, and then only the one's close to the screen side on the sides (hehe I hope you understand what I'm trying to tell you ;) )
The screen should be the first thing you see, if you loosen the 4 screws that hold that you can see the connection, just try to fasten it a little bit better, and then screw everything back to it's place.
Let me know if that didn't do the job :)
*I can not be held responisble if you decide to take something apart, It's your hands*
Feb 15, 2008 | HP Photosmart R817 Digital Camera
HP Pavilion dv9000z Notebook Logo
152 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
