Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 I also had the power light flashing 3 times and then shutting off. Got progressively worse, and now it wont come at all(still flashes). There was also the clicking/snapping sound with each flash. When it did come on , there were horizontal red lines on black/gray screens. Just figured power fluctuations. When it was still working it also had distortions. A little warped on the corners. Like I said, at first it would come on after a few tries. Then 10. Then 20. And so on. When it finally got up to about 50 tries to come on is when it quit.
  • 1 more comment
  • Dennis DeWitt Mar 06, 2009
    it also seemed to start shortly after hooking up a new panasonic dvd/vcr combo. model #DMR-ez47v. Hooked up the hdmi cable. dont know if that had anything to do with it, tho.
  • Dennis DeWitt Mar 16, 2009
    Changed out the flyback, and the cp 150, cp120, and cp114 capacitors. Tv is working and staying on now. But, obviously I had somethinbg going wrong before. Picture is a little blurry. Ran the auto convergence, and it worked. The crosses were even lined up. But there is a little of red of line on the left side. Especially on the bottom left. It seems to be doing this when the feed is coming thru the dvi/hdmi line from my dvd/vcr. Are my lamps going?? Or is it something wrong in the dvi circuitry??
  • Dennis DeWitt Mar 19, 2009
    No. I'm not a tech
    President:
  • 987 Answers
I believe it is a diode located shortly after the transformer that had went bad, possibly due to the power surges..
Posted on Mar 06, 2009
  • 495 Answers
I would say the power supply is not working. May be something as simple as a fuse. To check the fuses, a person must always to first, unplug the set from the wall. Then take the screws/1/4" nuts from the bottom back panel of the set. You should be able to take a flashlight and observe any bad fuses, or better yet, if you have a continunity checker ( vom/dvm ) use that to check each fuse. There are usally more than one in a big screen. Good luck. I hope this has helped.
  • 154 Answers
There is some internal damaged on the main board needs a repair. are you a tech.?
Model d52w20b the green light comes on flashes 3 times but the tv wont come on the green power light is supoose to stay on
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
Jan 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rear projection hdtv power button flashes 3 times then shuts off and wont power up...what do i do?
Install the RCA repair kit called CP150, CP120 and CP114 repair kit available from www.tvrepairworld.com the kit also contains the CD with detailed repair instructions.
Dec 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Sep 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light flashes 3 times, but never powers on.
Most probable cause is the CP150 and the CP120 and CP114 capacitors. You can get the replacement capacitors with instructions at the following link under RCA parts category.
http://servicemanuals.vstore.ca/
Jul 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA rear projecton model number D52W20
the rca itc222 will shut down for any of 25 different reason. the fact that u see a flashing light lets u know one thing it is not the main fuse. the most common reasons for shut down involve high voltage parts. In the shop we have a computer interface that let us diagnose much like error codes in a car. the d52w20 is a old version of the tic222 and average repair at my shop is 250 to 400 and if its the tubes then it wont be worth fixing. tubes run 250 apeacie and by the time labor is put in that can run as high as 1000. I SEE ALOT of these at shop. How are you with electronics. rember this set can hold a charge and can be dagerous
Mar 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca scenium hdtv M# D56W136D
does the power light flash 3 times then go out? Let me know and I will assist you with the problem
Sep 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light flashes
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
