Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
My LG fridge is on but is not cold any more and i thought the gas is finished and i called technician to look at it he says i must take back to LG factory he thinks the pipes are leaking from inside ,so all i need is the contact numbers or should i go back to House Home in Sandton where i bought it please help am staying in Alexandra North Jhb
  • 400 Answers
Hi there, you can call the service department at 011 571 6700, make sure that you have your proof of purchase document with you and I am sure they will sort it for you, cheers and goodluck
Posted on Mar 06, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
LIGHTS WORK IN FRIDGE AND FREEZERS BUT FRIDGE DOES NOT RUN AT ALL..ANY ADVICE ON WHAT TO TRY
there is a small copper bottle connected to the compressor and to the thermostat, if finish, your fridge will not work, call a technician who repairs air conditioners to have thermostat replaced, and check whether there is gas in the compressor
Feb 22, 2015 | Amana Refrigerators
Fridge not cooling; fridge temperature staying at 19c. power cool button not changing the temp.
On these models the technicians want to sell you circuit boards and other parts. These parts usually do not solve the problem.
First to get your fridge cold again. Remove all the drawers and shelves on bottom of fridge side and remove
rear panel to inspect coils. If coils are covered in clear ice like a solid block, then thaw/defrost this. A hair dryer helps.
Pour hot hot water into this area when finished until it runs out the drain at the back of fridge. The frozen solid drain is the problem. When finished use blocks to raise front of fridge so it leans slightly back. Supposedly this helps the drain from freezing again. The product is inherently defective and designed poorly, your problem is quite common.
We completely redesigned the drain on ours (not recommened for most people) and it works okay but I cannot wait to replace with a different brand.
Jan 23, 2011 | Samsung RS2534 Side by Side Refrigerator
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not cold
Sounds like your fridge is running out of gas,, Call a Aircondition or Refrigation technician and let him re gas it for you...
It cant be frost cause it sould have affected your freezer not your refrigation unit.. Normall when gas is running low the first thing that is affedt is the refrifgation section ,, the freezer shows signs a few days / weeks later and eventualluy stops cooling all together... RE GAS IT FAST BEFORE IT BURNS YOUR COMPRESSOR OUT..
Jan 15, 2008 | Refrigerators
Freezer just not getting cold enough. Freezer fan is running. Gasket, I thought was the original problem, has been re aligned. Light switch works and the light goes off when freezer is closed. Cold air is...
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
May 05, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
231 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
