Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 4GB Kingston usb drive cannot be opened..when I right click or left click on the icon, my computer stucks..
    Problem Solver:
Posted on Mar 06, 2009
How can i download a music .save to my usb?
1. 1. Connect your USB Flash drive to your computer.You can do this by locating an unused USB port on your computer. 2. Locate the my computer icon on your desktop,provided you are running one of the various Windows operating systems. Doubleclick the my computer icon. You will see a drive labeled as removable drive orflash drive. Double click on the drive. Leavethis window open, proceed to next step. 3. 3. Locate the music files that you havedownloaded/save to your computer. Usually the default location will be "My Music" folder under "MyDocuments". Open the folder that you have downloaded/saved your music in. 4. 4. Highlight the music file and right click. Pickthe copy option. Next go back to the window you opened for you flash drive instep one. Right click in this window and click paste. You should now see yourmusic file in this window.
Jul 17, 2011 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
Can't remove write protection from my kingston datatraveler 4gb g2
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Most of the time running a disk check first will fix your problem.
Right click on your drive's icon in "My computer"
Select properties. Go to the "tools" tab, select "check for errors".
Depending on the operating system you use, this could also be called "run scan disk", "run disk check" or "check for errors".
Jan 21, 2011 | Kingston 4PK 4GB USB 20 DATATRAVELERI GEN...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
use any low level formatting software....
Oct 21, 2010 | Kingston 4GB Secure Digital High Capacity...
How to format my disk write protect usb?
on the memory card to the left r right side ul find a tab see towards where unlock is then push the tab till there. After doing it insert your disk to computer go to "my computer" youll find the disk icon right click on that ul find format option double click on that then press ok
Sep 19, 2010 | Kingston 4GB Secure Digital High Capacity...
Computer shows the pen drive without its name. But when I try to open it gives message 'insert disk in drive F'. I started my computer keeping pen drive attached to it, in tis case, the message is ' format...
Sep 01, 2010 | Kingston 4GB Secure Digital High Capacity...
When i insert a pen drive usb device can not recognised message displays and i cannot open my pen drive
in this case you can check whether your usb drive is disable or not
by doing right clickon my computer icon then properties - hardware - device manager - in device manager below you will find usb check if you hav any red cross in that if yes then do a right click and enable it
other wire do a right click on usb and then scan for hardware changes
OR try to to put some other USB device and check if that works or not
Mar 04, 2010 | Kingston 4GB Secure Digital High Capacity...
Cant open or format 4gb kingston flash
Right click on My Computer, choose Manage
A Computer Management console will appear.
On the left lokk for Disk Management and click on it.
Wait a little until the values on the right loads.
Now locate the Kingston drive, right click it and format it.
Don;t forget to rate this answer if it helps
Jul 20, 2009 | Electronics - Others
I don't know how to save to the kingston 4GB USB2.0 data travelter - no instructions with it
You just plug it into a USB port and your computer will automatically detect it.
Please rate this solution and thanks for using FixYa
Jan 06, 2009 | Computers & Internet
right click on your folder which contains your photo's, or you right click on a single photo in your folder. Then select "copy". then locate your usb on your "my computer" folder. left click on this icon. Then select paste with your left mouse button.
Aug 18, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
81 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
