Question about Kohler Trailer Wall-Mount Lavatory, White
I am trying to fix a wall mounted Kohler toilet but I shut off the water,removed the flushometer, drained the toilet and unbolted the two bottom bolts out of four then proceeded to lift up on the toilet and tons of water continuously came out of the drain? Please help!!!
  • Cameron loker May 11, 2010
    sound like you have a back up or one of the other tolets it running in the same bathroom.
  • 224 Answers
This, or after you broke the seal of the wax ring, the water that was in the trap has voided. It's normal to have a good amount of water rush out when you first remove the toilet. That and there is still a bit of water in the tank and once you remove the fill valve, it escapes from the hole that is left. Proceed to install the new toilet and everything should be okay, just clean up the old water.
Posted on Jul 10, 2009
WHERE CAN I BUY KOHLER 81100 FLUSHOMETER REPLACEMENT SYSTEM
you are in the toilets and bidets catagory so go to a plumber supplier shop and ask then what unit will replace the item
Sep 23, 2016 | Kohler Home
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
I have two (back to back separated by a wall) Kohler toilets. Model K3589-47. One is always loosing the water in the bowl. It leaks out slowly but always does it. When I flush the toilet on the opposite...
You will need to check the drainage fitting these toilets are draining into. If it is a cross tee fitting without a baffle you are getting throw over across the fitting and it will not stop. The only fix for this is to replace the fitting in your drainage system. In Illinois it is a code violation to put this type of fitting in that application.
When these power flush toilets come out it made this problem worse. In short there is no fix for this problem other than redoing the drainage system.
Feb 10, 2011 | Kohler Home
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
Flushometer will not stop flushing
The diapharm inside is got trash not allowing it to seat and shut off water.
Oct 26, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
My flushometer toilet will not stop flushing. The
Try checking the water pressure. If it has dropped too low then the valve will never re-seat properly. Ideally over 90 psi.
Apr 02, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Not enough water ,need flush it 3 time in regal flusometer
the right side where water comes to it through wall there is a cap that can be taken off it covers the shut off valve that takes a flat head screw diver to shut off or open up all the wall. check and make sue it is all the way open.
If it is shut it off and the cap on top where the flush handle is remove it once water is turned off and check it out. the kits to rebuild one it should be a 37-a or 36-a to replace this part if that is it.
These are a couple of thing's to check
Jan 21, 2010 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
I bought a Kohler Primary Elongated Bowl Toilet with Seat (K-4321-0); I need a tank but don't see one that goes with it. Help!
You cant find one, because Kohler doesn't make one. It is a commercial application and uses a flushometer. Sorry
Aug 12, 2009 | Kohler Primary K-4321-0 White Elongated...
Kohler Trailer Wall-Mount Lavatory, White Logo
206 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
