Question about Kenmore Dryers
The dryer wont turn on the status lights blink and thats it. what could the problem be? and how much would it cost to fix it? the model # is 417.88042700 serial # xd73808322
  • 686 Answers
Check your thermal fuse or have it checked out
Posted on Mar 06, 2009
How do I fix the Television that has a constantly blinking re status light and will not come on?
re-install the lamp door cover if you own a mitsubishi. they wont run without it.
Jan 28, 2015 | Televison & Video
My dryer wont turn on, the lights are blinking off and on but cant get the buttons to work
Typically, that would be caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
There should be an electrical schematic diagram attached to the back of the unit. You may be able to use that to identify the faulty part. Don't be surprised if the replacement board costs alot more than it's size and simplicity might indicate.
Oct 19, 2014 | Crosley CDE6000 Electric Dryer
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Dec 16, 2013 | Kenmore 800 7982 Dryer
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
Sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
Nov 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsubishi WD 52527
I finally broke down and took it to the shop. They said they think I had some loose connections internal to the engine. They reset all the the connections and resoldered the joints. Seems to be woking okay so far. The fix cost me $310.
Oct 28, 2007 | Mitsubishi WD52527 52" Projection HDTV
Dryers Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
