Question about Panasonic PT-47WX49 47" Rear Projection Television
Convergence problems convrgence lines horizontal and vertical. the line will be on the mark on the bottom. try to put it on the mark at the top then it will be off on the bottom. same thing side to side
  • 9 more comments
  • kent ggg Mar 06, 2009
    hmm. dont know much about tvs. how much do you think to fix it? i just got this tv today for $150
  • kent ggg Mar 07, 2009
    thanks, helps a lot. at least i know what to expect if and when i get it fixed. one more quick question. im new to these rear projection tvs. im wondering if putting my powered subwoofer behind the tv will affect the tv at all?
  • kent ggg Mar 10, 2009
    thanks, i didnt think about magnetic waves at all. i was more thinking about the vibration. roughly how far away should i have it away from the back of the tv?..ine question keeps leading to another.
    also would that be affecting the convergence at all??
    does that mean sub on either side of the tv...do you know what kind of ic's i will need
    are ic's and semi conductors the same thing...when ever i look on ic's. it gives me semiconductors
    Panasonic Part Number: C5AA00000203....found this...may it be the right one
  • kent ggg Mar 12, 2009
    got a prob...cant get out of the service menu
  • kent ggg Mar 13, 2009
    i was trying to get out of the service menu when my screen just blanked out, have a bowed streaky snow storm goin about 10 inches down my screen. do you know what may have happened???
    could the ic be replaced by me, or would i need a technician
    what is the stk # for the ic/ic's, does it have to be from a panasonic tv or any brand? i am trying to track one down on ebay right now
  • 905 Answers
The convergence IC's will need to be replaced and all resistors on them checked for thier values for possible replacement as well
Posted on Mar 06, 2009
  • 12 more comments
  • jason Mar 06, 2009
    if you call a qualified electronics repair shop the cost will be aproximately $350 to $400 or more , depending on shop and location
    the IC's are not exspensive ( aprox. $60) , its the labor
  • jason Mar 10, 2009
    if the magnetic wave from the subwoofer magnet is close enough or the sub is close enough , then yes this will definately effect the tv.
    the "CRT" "Cathode Ray Tube" gets effected by strong magnetic waves
    yes this magnetic wave can and will effect the crt's , you also have to worry about adjusting the convergence to earth's magnetic field , you can see that here http://www.fixya.com/support/p231755-pan...
    depending on the strength of the subwoofer and its amp , it should be at least a few feet or so
    how many watts on the subwoofer amp ? and what size speaker ?
    this is an ideal setup for the sub
    Left speaker center right speaker
    (TV)
    +++(sub) <----> <----> or subwoofer
    here
    Left surround right surround
    sorry the tv was supposed to be in the middle
    IC or "Integrated circuits" is the make up of the "CHIP" and they(Your STK392-110 convergence IC's are semiconductors , but your upgrade should be the STK392-180
    here is the STK392-110 http://www.nteinc.com/specs/7100to7199/p...
    also, yes that part number will work
  • jason Mar 12, 2009
    EXITING SERVICE MODE
    1. power button
    2. unplug from wall(AC)
    3. power button and action button(same time) on tv for at least 2 seconds
  • jason Mar 13, 2009
    convergence IC is out now
    if you have never soldered or don't know how to get old solder off and check resistor values that are inline with the IC's with a meter , then you will want a tech. to do the repair to make sure that there is not a resistor or other component that is the cause of the STK IC breakdown
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs convergence problems - 578ba6c.jpghanged.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from
www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
Green convergence on Panasonic PT-53WX42 is not ligning up...
Does not sound like the chips are bad.
What you need to adjust is "SKEW". You need to enter "service Mode" then go into "Coarse Convergence". Skew can be adjusted for all 3 colors. Unless you have the service manual, these corrections should not be attempted.
To clean the INSIDE of the screen, you really have to disassemble the TV. Remove all the screws that hold the "back" ( the piece with the mirror) to the front (screen) assembly.
The screen can be cleaned with a solution of diluted isopropyl alcohol, no more than a 50% solution. Drugstores will carry it, but it might be 70%-90%. Just dilute with distilled water (not tap water as it contains minerals). Personally I have used 70% with no ill side effects but 50% is recommended.
Dec 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Red horizonal convergence tilts instead of adjusting evenly.
For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
the convrgence board.
Good luck
Dals123
Oct 09, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Convergance problem
replace the two STK392-110 convergence ICs. You can get replacements at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
57H81Toshiba Blue Line not straight
You have a bad convergence output IC in the blue vertical circuit. On the bottom side of the chassis you will see a " V " printed by the heat sink. You will need to unsolder the heat sink and the 20 pins on the IC to remove it. Replace with STK 392-180 (sanyo) if possible or STK 392-150. Looking from the rear the heat sinks are big aluminum finned rectangles. There are 2 heat sinks one marked H and one Marked V. Even though you have a horizontal line your problem is in the vertical IC. Be sure to use a liberal dose of heat sink compound.
Mar 21, 2008 | Toshiba 57H81 57" Rear Projection...
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
329 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
