Question about Yamaha HTR-5990 Receiver
4 ohm speakers with 8 ohm receivers
I would like to know if i'm losing sound quality becoz i have 4 ohm surround speakers but my receiver is rated at 8 ohm per channel.
  • ghostridercj Mar 06, 2009
    its a sony strdg720.
    thanks man. i'm getting new yamaha speakers today rated at 8 ohm so i think i should be good.
    Novelist:
  • 98 Answers
Please check with the manual of your receiver whether it is capable of running 4 ohm speakers.
if yes, then please go ahead, you will not loose any Sound quality. Sound quality will depend a lot on the performace of the speaker as well as the frequency range it can deliver.
If no, please do not connect. Though, you might be able to play and listen to the music, but it will overload your receiver!!
If you are not sure, please let me know the brand and model of your receiver and I can check for you.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 06, 2009
  • Sachin
    Sachin Mar 06, 2009
    Thanks,
    Sony STRDG 720 is rated 105Wx 7 at 8ohms. If you see the back of your receiver, you will note that Sony has specifically written near the speaker tereminals: Speaker Impedence = Use 8 to 16 Ohms.
    It is recommended that you pick up a pair of 8ohm speakers for your surrounds to connect with this receiver. Though, of course you will be able to run the 4 ohm speakers that you have but it might spoil you receiver in the long run.
    Just for you to understand my logic for my recommendation is that a 4 ohm speaker places a heavier load on the amp. The advantage being, you get more power, the drawback, the amp runs hotter, and it needs to have enough reserve and current capacity to handle a 4 ohm load without clipping or overheating.
    Thats the reason most car speakers are 4 ohm, so that you can get higher power levels out of amps driven by a 12 volt electrical system, without having to use an inverter to boost the voltage.
    An 8 ohm speaker requires twice the voltage to get the same amount of current through the coil as a 4 ohm speaker. While this isn't really an issue with home equipment, which can provide a higher voltage so accordingly amp/reciever are built that way.
    Thanks and enjoy connecting.
Speakers
All speakers can be 100 Watts. The Front speakers can use 4-8 ohms. Center and Surround jacks can use 6-8 ohm speakers.
Mar 31, 2014 | Panasonic SA-HE70 Receiver
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Impedance setting on Yamaha AV Receiver
Hi. You can always use a Receiver with an output impedance that is lower than the speakers input impedance.Problems arise when you try to use a Receiver with a higher output impedance than the Speakers input impedance.
Receiver 6 ohms speakers 8 ohms......YES..
Receiver 8 ohms Speakers 6 ohms.......YES, WITH CAUTION
Jan 15, 2013 | Yamaha RX-V673 7.2 Channel AV Receiver...
I just purchased a yamaha RX-V767 receiver. I have a polk surround sound speaker system 5.1 that have an impededance of 8 ohms. The receiver has an impedece adjustment knob on it. would it be safe to...
No, you don't want to do that. The Ohm output on the amplifier must match the speakers. Run 8 Ohm speakers on 8 Ohm and run all your speakers on the same impedance (Ohms). Your gonna burn your amplifier up if you run different impedances.
Mar 24, 2011 | Yamaha NS-A60X Main / Stereo Speaker
What receiver would you recommend for bose 301 speakers? someone suggested Onkyo 7.2 Channel 3D-Ready Home Theatre Receiver HTRC270
Anything with good clean power not overdriven will sound just fine.
If you can afford them and have the space for 5 (or more) I'd highly recommend them. Matched full-range speakers will yield the best surround experience. You might not even need a sub.
I have several iterations of 301's up to Series IV and they sounded awesome as fronts but I prefer my 901's so the 301's serve aurround duty now.
The manual prescribes >>>
301: Compatible with amplifiers and receivers rated from 10 to 150 watts per channel. Rated 4 - 8 ohms
Mar 06, 2011 | Bose 301 Series V Direct/Reflecting...
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Denon AVR-2307 Protection Circuit Activated permenantly
The speakers are 4 ohm speakers, a guy on another chat site sent me a link to the impedance curves http://www.audioholics.com/reviews/s...t-v2-fs/page-4
He agreed to that there was a mismatch as the unit has plenty of fresh air around it, plus all the speaker cables have been tested and installed correctly.
So, off to the store where I got it from tomorrow.
Jan 02, 2009 | Denon AVR-2307 Receiver
4 ohm speakers for 8 ohm impedence on receiver (HT)
ya cant run them 4 ohm on 8 ohm sterio run super hot then fail sooner gota get sum nice 8 ohm ones ok flouece off ebay is relly good cheap 8 ohm
Jan 24, 2008 | Ohm L Speaker
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Sep 14, 2007 | Sony STR-D865
Yamaha HTR-5990 Receiver Logo
1,050 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
