Question about Mitsubishi WS-55511 55" Rear Projection Television
MITSUBISHI TV WILL NOT POWER ON
DAUGHTER TURNED TV OFF, AND IT WILL NOT POWER BACK ON. WE HAVE UNPLUGGED TV AND PLUGGED BACK IN. WE HAVE DONE THE SYSTEM RESET BUT NOTHING SEEMS TO WORK.
  • bradlap777 Mar 24, 2009
    Two year old played with the TV controller, turning TV off. It will not turn back on, even after trying the unplug reset.
  • 139 Answers
Check the lamp.
Posted on Mar 06, 2009
We had a power outage during a lightning storm this past weekend. We turned on the TV the next morning and it stayed on for 20 seconds then turned off. We rebooted it and same results. Thers is no audio...
Try power cycling the TV. First, unplug ALL cables from the TV, This may sound silly but there can be minute amounts of power coming from your other devices like the cable box or BluRay player and that small bit of power is sometimes enough to hold an electronic device in a particular state. Once they are unplugged, unplug your TV from the power source. Leave it out for a full 60-90 seconds.Reconnect your devices first, then reconnect the TV to its power source. If this does not work, there may have been damage done by way of a power surge.
May 05, 2011 | Televison & Video
TV will not power off and volume now does not work - volume stuck on current setting
My TV done this one week ago. I unplugged it for 10 seconds and then plugged it back in. Turned it on and it worked fine. Guess it reset itself.
Jan 20, 2011 | LG 42LC2D 42 in. LCD HDTV
No picture after replacing lamp
the chassis needs to be rebuilt. go to www. tv-techs.com for more info
May 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
The tv keeps shutting down
i unplugged the tv , turned the lamp switch to off . I left it unplugged for a few hours . I then plugged the tv back in , hit the reset button , located on the front bottom left . I waited for the timer light to stop blinking , then turned the lamp switch to the on position . I turned the power on to the tv . i heard the fan kick on , this time there was not a dragging sound . the screen lit up and i have not had a problem since yesterday . i think that the problem started because the tv had been left on for too long , I know that what i have done is only a temperary fix . but as long as I dont forget to turn the tv off , i should not have a problem
Mar 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-45609 TV While having problem with convergence on my TV, I tried to adjust the settings. As I was messing with the buttons the TV froze and no buttons would work. I unplugged it to turn it...
I am at the same state your in the tv from back side of it inside holds 3 little glass fuses did you check those? for fuse pop i did mines still good
but still wont power back on just a quick blink from front when the power is plugged back in
Feb 20, 2009 | Mitsubishi VS-45609 TV
50604 tv is trying to program channels how do i stop it ?
have a look here for your replacement mitsubishi remote:
http://www.electronicadventure.us/mitsubishi.htm
regards
Nov 26, 2008 | Mitsubishi VS-50604 50" Rear Projection...
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
