Question about Acer Aspire 3680 PC Notebook
I want to run 3 gig ram in my acer aspire 3680
It will run a 2 gig strip but it wont boot if i put a 1 0r 2 gig strip in the second slot
  • mchl_hopkins Mar 06, 2009
    I just got 2.5 gig to run, 2gig in the first slot and a 512 in the second, but I still get a gig to run in the second
  • Roger Gantner May 11, 2010
    1 0r wha?
I just now put a 2 gig stick in slot 1. it'll run the single stick of 2 gig but wont fire up if i put anything in the other slot... just thought you'd like to know...
Posted on Jun 19, 2010
  • Acer Master
  • 32,281 Answers
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Posted on Mar 06, 2009
  • Chris Hingee
    Chris Hingee Mar 06, 2009
    Further info.
    Dual channel support means you need two memory modules, one in each DIMM slot, therefore you need to purchase two 1Gb memory DIMM modules to get a max of 2Gb RAM.
2 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: I can't get 3gig ram to boot in my Acer Aspire 3680 Notebook
Well let me start by saying that it should work. But without being there to see first hand check this out..also make sure you don't have a bad RAM stick by putting it in another machine to test. If all is well then follow directions below:
This is a tool you can use not only for memory but it will give you all the information you need for anything on your computer including slots for RAM and how much you can use. Go to www.cnet.com. Search CPU-Z and download it, it is freeware, already tested by CNET. Run the program and it will show you exactly how to set up your RAM...Let me know if you have any questions.
Rate this solution with 4 diamonds.
Battery light blinks on Acer 3680 but won't boot
yes you have a problem inside your laptop.find the slot of memory then remove easy the memory then make a clean the memory then put it back again and try to but the unit.thats all...good luck and i hope its done..thanks
Jan 09, 2010 | Acer Aspire 3680 Laptop
I have an acer aspire 3680. when i turned it on, the fan,hdd works but the screen turn black. i did try to connect it a VGA screen but i's not on. is it the mainboard problems?
you may consider if no display at LCD and VGA monitor both:
1) you may change RAM or change the RAM slot
2) take out the wireless card from MINI PCI slot
3) still black screen that should be any damage of display chips or isolated memory (all BGA chips)on the motherboard
hope it help you troubleshooting
May 08, 2009 | Acer ASPIRE 3680-2022 Notebook
Test the second stick of memory in the first slot. Confirm that the second stick is not a problem. If it works, then you have a bad slot on the motherboard. Oh, and one other thing--make sure the memory stick speeds are compatible. Match the memory speeds where possible. Post back your findings.
Mar 06, 2009 | Acer Aspire 3680 Notebook
Memory upgrade for Acer Aspire 3680
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot so you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS hope this helps pls appreciate by rating as fixyaa.thanks and Godbless.
Jan 07, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 too slow
Sure but if it has acually been slowing down you must also find the problem. Have you disk cleaned up and defragged your hard drive lately. Cleaned out all the junk from your internet exploier?  Have you gotten rid of everrything that you don't need or want. Slowest thing in a computer is the Hard drive seek/read time.
  According to you manual (Link below) You can have up to 4GB total memory. Two strips of 2GB each soDIMMs
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=1016&formid=3425&website=AcerPanAm.com/canada&siteid=7297&words=all&keywords=&areaid=17
Jan 04, 2009 | Acer Aspire 3680 Laptop
Installing new ram
open back plate of your laptop. then u see on top of battery the ram slot.
fix your ram.into it.
check also there is any other ram?if there is u must check both ram frequency and chip company.
Oct 11, 2008 | Acer Aspire 5630 Notebook
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
RAM ON acer computers
Yes... just need to purchase the right stuff.
You need to determine if you have DDR or DDRII. And then determine if you have one stick of 512, or if you have 2 sticks of 256. Once you know this information, visit your local Best Buy or purchase somewhere online, a memory upgrade. Such as 2 sticks at 512mb for 1 gig total. Assuming you have two memory slots, should have anyway.
DDRII is fairly cheap right now, be a good time to upgrade. DDR on the other hand, is still a little more expensive.
Oct 30, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 PC Notebook Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
