Question about Proscan Televison & Video
PROSCAN MODEL 80690 REAR PROJECTION TV
I am trying to find a supplier of spare parts for a Proscan model PS80690 (80 inch) rear projection tv (in Australia if possible)
The parts required are qty 1 of each part number 40431090 Tripler and part number 2525034 High Voltage Transformer (this part number is a little hard to read as the number could very well be 2625034.
SOURCE: proscan ps56670
Power problem
Posted on Sep 03, 2007
ctf1800
  • 4402 Answers
SOURCE: ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Posted on Dec 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: i need a part #
Your model has the CTC195 chassis which has flyback number 239111 you can get a replacement at the following link for 13.99. hope this helps here is the link.
http://www.electronix.com/catalog/product_info.php/products_id/13075
Posted on Feb 10, 2008
SOURCE: ProScan Projection TV PS60690 shuts off
replace the small 5G5A125V fuse in the back where the power cord connects the to chip
Posted on Sep 02, 2008
  • 298 Answers
SOURCE: Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Posted on Apr 10, 2009
What's your problem?RCA PROSCAN PS52800 52-Inch Digital High-Resolution Projection TV Monitor/Receiver, no audio
Audio circuit problem and likely parts are no longer available due to age of set----some shops may tackle this set for repair or not..........
Oct 29, 2012 | Proscan PS60690 60" Rear Projection...
I have a 50 inch proscan and it just beeps but will not come on how can i fix it
I suspect wrong model number is listed here as this set makes no beep at turn on; older set made around 2000 but if it is your model here is some information to look at.
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Proscan-PS50700-projection-TV.htm
If not this model let me know.
Apr 17, 2012 | Proscan PS50700 50" Rear Projection...
Splitting a RCA Proscan 60 in 2
If there are plastic plugs on the sides of the tv (4) then you can take them out and expose a screw that if taken out will allow for this, otherwise you will have to get creative. good luck
Aug 29, 2009 | Proscan PS52690 52" Rear Projection...
How to remove front screen on proscan projection tv model 50700
the front trim pops off and behind that there are screws that hold the glass in place. once you remove the screws you can access the screen and clean the tubes.
Feb 23, 2009 | Proscan PS50700 50" Rear Projection...
I HAVE A 80 INCH PROSCAN REAR PROG TV AND THE ON/OFF SWITCH WILL
it sounds like the main power supply. unfortunately spare parts are no longer available for this model
Feb 21, 2009 | Proscan PS52690 52" Rear Projection...
Proscan PS61700 Beeping no picture
I have a 60in Proscan Projection TV. My picture is out and the TV only beeps.
Brian Allen
Feb 03, 2008 | Proscan PS61700 60 in. Rear Projection...
Proscan PS5067 52 in. Rear Projection TV
Try unpluging the tv for about an hour. I have the same problem and a tv repair man suggested the solution. It work every time I have the problem, although it is happening more often now.
Nov 08, 2007 | Proscan PS52800 52" Rear Projection...
ProScan 60 inch TV Problem
Have you had any luck with a repair or adjustment?
Oct 09, 2007 | Proscan PS60690 60" Rear Projection...
Will not power up with panelswitch or remote
If you still have this unit and would like to sell any of the optical components please email me. kievsavoie@hotmail.com
Sep 01, 2007 | Proscan PS80690 TV
Tv problem
what chassis is in your set,look at the rear panel for model and chasis type to help to diagnose fault
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
