-   same problem when sending fax,i have to push the page down to get it started one at a time.Is there an easy fix for this like cleaning something inside?-   billyo69
Not sending multipage faxes I will assume the pages are not feeding correctly. If this is the case replacing the entire ADF would be the easy fix.
Not available new from HP as far as I can tel but available if you search G85 ADF.
If machine is terminating the connection try reseating th LIU this is the board the phone line plugs into. part C6735-60009
Hope this helps
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone...
(More)
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone line is good. I probably have it hooked up wrong but I do not know. Help!
Half empty black cart stopped printing, error message to replace. New cart also didn't print. ...
(More)
Half empty black cart stopped printing, error message to replace. New cart also didn't print. Repeated cycles of clean and prime did nothing -- nothing but fill the bottom of the printer with a puddle of ink. Troubleshooting page suggests cleaning or replacing the cartridge service module. Is this possible on this machine. Is it a dead puppy or worth fixing?
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in...
(More)
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in color. Thank you.
Getting a message that says Report Job queued when trying to re-align. When I try to align it spits...
(More)
Getting a message that says Report Job queued when trying to re-align. When I try to align it spits out a blank page and flashes "Report Job Queued" then says alignment failed.
Hi, I am trying to scan and print a document on my printer and when I put it on the scanner and hit...
(More)
Hi, I am trying to scan and print a document on my printer and when I put it on the scanner and hit "start copy" my printer says it is jammed but I can't find any jams, It reads: "Original jam:" I've tried hitting enter and cancel but it won't let me scan it. Any help is appreciated. Thank you.
