Question about RCA P52926 52" Rear Projection Television
Colors disorted colors are distorted and unfocused
  • samnrandib Mar 06, 2009
    is the IC expensive?
  • Anonymous Mar 14, 2009
    What is the cost?
  • 790 Answers
Hi
this cause by a defective convergence IC, this ic nedds to replace
Posted on Mar 06, 2009
Samsung ln46a550p3f has distorted color
what do you mean by distorted?
are colors wrong? or are colors washed out?
Mar 29, 2014 | Samsung LN46A650 46 in. LCD HDTV
Color distortion-Sony Bravia Model KLV32EX500
check for a loose connection in the t-con board tried with re seat the cable wire in the t-con board.
Oct 04, 2012 | Televison & Video
When tv turns on the picture is disorted
if picture is 3d looking with colors skewed etc it is convergence--tell me as much as possible as if model listed is correct I know it well.
Aug 26, 2012 | Mitsubishi WS-65807 65" Rear Projection...
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
My color on my comp is distorted different colors whats wrongs
pls. degauss your monitor. thats why so many colors appearing.
Jun 25, 2009 | E-Machines eMachines T3830 PC Desktop
Unfocus colors sceen
Very likely there are bad connections on the flyback transformer and a fuse has opened up. The convergence circuit is not working. this is not easily done yourself unless you have some experience.
Apr 14, 2009 | Televison & Video
Colors out of porportion, maybe a bulb went out
When you have a 3-d effect. this is called convergence. Is the picture disorted or bowed in. if the picture is bowed in then this is an indicaTION of complete loss of power to covergence curcit. I always check to see if you have the convergence option in the setup menu if you do not then i suggest reading the fl231 problem in the tips and tricks sectionl
Mar 15, 2009 | RCA HD52W58 52" TV
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
Color disortion
colors all messed up, looks like 3-D ??   convergence amps and possible a few resistors are bad
Oct 23, 2007 | Hitachi 57F500 57" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
