Question about GE Profile JGB900 Gas Kitchen Range
Ge Profile model jgb900 has error codes & oven doesn't work
The digital display for a GE Profile stove model JGB900SEK-1SS is showing an F9 error code & another code. I read on a blog that someone cleaned the contacts on the ribbon cable. I did that & it worked for a while but the code came back. Is it the push button circuit board or the EC board that needs replaced? Can anyone tell me how to trouble shoot this problem? The oven doesn't work at all when this code is on. It worked fine when I cleared it temporarily. Help
  • jmatejovich Apr 14, 2009
    I replaced the oven control board scince I was told it was either that or the whole top panel has all the pressure sensitive switches. The ocb didn't fix the problem so I called for a GE service tech. After an $80 service call the tech told me that an f9 code is always the front panel with the swiches in it. I ordered the whole top panel & installed it & it works like a charm. So if you see an f9 d7 code change out the top panel. I now have a oven control board that cost $140 they won't take back because I installed it. It would be nice if GE would publish a list of the error codes & what they meant to prevent someone from having to have a service call but I don't see that happening anytime soon. JDM.
  • 6,784 Answers
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Posted on Apr 14, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Apr 14, 2009
    what was the other code you stated that was showing?
  • Michael Masters
    The F9 is a lock switch failure.
  • Michael Masters
    Michael Masters Jul 31, 2009
    (((F-9)))
    This is a lock switch failure code.
    Check wiring to door lock switch (the wire harness may be connected
    wrong). Check for stuck lock switch. If the switch is stuck, this will confirm mechanism failure. replace this damaged lock switch asap.
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
My GE Oven JTP 14 displays an F9 error and shuts off.
F9 error - Lock switch error.
Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Hope i helped you.
Thanks.
Sep 02, 2009 | GE Profile JTP18 Electric Single Oven
Hi, my GE Profile Mod# JBP90GV2BB S/N ZM223214G began beeping this morning and posted an F9 code in the display. The stove hasn't been used in 2 days. What does the F9 code indicate and what ccan I do to...
F9-- Failed Lock switch detected.
If the wires are ok and, the switch is not stuck, replace it asap.
Jul 10, 2009 | GE Profile JTP18 Electric Single Oven
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
GE profile gas stove over does not work....F7 D8 on screen
spectra stove and it is beeping and reading f7 we have unplug it and replug please help me
Nov 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE FTP18
I have the same problem, although my oven is 3 years old. I am having the door latch replaced today. cost $240. The repair company that I contacted sid that these ovens are their bread & butter!!! If I could afford it I would ship all of my GE appliances(which are only 3 years old mind you) to them and tell them to shove them!! I alreadt spent over $200 on my GE dishwasher which at the time was only 1 1/2 yearsd old.Did you clean the oven before the error code started flashing?laurieslovett@yahoo.com
Jun 25, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JGB900 Gas Kitchen Range Logo
544 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
