Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
DETERGENT DISPENSER NOT EMPTYING ON DD603SS
HI!
THE DETERGENT DISPENSER FOR THE BOTTOM DISH DRAWER ON MY FISHER PAYKEL DD603SS IS NOT EMPTYING WHEN IT GOES THROUGH A CYCLE. WHENB IT DOES A WASH THE DETERGENT IS STILL THERE AND IS DRY! HOW CAN THIS BE FIXED
CHEERS DERYCK
  • 205 Answers
Hi- It sounds like the solenoid on the dispenser is not changing the water diverter to the wash portion (cup) of the dispenser. You most likely need a new dispenser. Probably best to have a Tech out to change it.
Posted on Sep 23, 2010
Dish drawer not emptying properly
check the waste hose is not kinked or blocked. otherwise replace the rotor at the bottom of the drawer. this can be accessed by unscrewing the panel at the bottom of the drawer.
Jul 10, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Leaking clear water from behind the faceplate
Most likely the lid seal and/ or the detergent dispenser seal is leaky. Do not operate the dishwasher in this condition as the water can cause electrocution because the mains voltage comes up to the drawer front panel. Most likely it is the detergent dispenser seal.
see this diagram.
http://spares.bigwarehouse.com.au/images/files/18816_a21ebb5ac093d66472cef9bd1e8f3b12.pdf
Feb 16, 2014 | Fisher and Paykel DD24DCX6 Dishwasher
After a cycle the dispenser is filled with water. The dishes are clean, the detergent is gone, but there is water filled in the dispenser. Thanks!
There is a small drain hole in the bottom of the dispenser. Most likely it is blocked. Try a toothpick or similar to unblock it.
Feb 11, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD603ss ,bottom draw does not slide out easy,,,,
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Apr 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer of the fisher paykel dish drawer seems to be leaking jet dry? I have to refill it continuously. Any ideas?
the small check valve in the rise-aid pump is bad. i'm having to buy a replacement soap/rise aid dispenser from ebay.
Oct 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
DD603SS DISHWASHER PROBLEM
This is simple you need a new Detergent dispenser fitted in the bottom drawer. cheers
Mar 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
477 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
