Question about Canon XH A1 Mini DV Digital Camcorder
My Canon XHA1 is not powering on At All!! Please Help!
My Canon XHA1 is not powering on at all, after inserting the battery and powering on the camera, it turn on for not even a sec then the light dim down, im not even able to eject a tape from the camera.
  • yeongheo Mar 27, 2009
    My camcorder(canon xha1) power on VCR/PLAY mode is very well with other mode not power but after No power off this on camcorder.
    This is already the 3rd time the same problem but once more... same problem again... my god. This defected.
    But this is same problem happened 4 times within 1 year.
    Sergeant:
    Champion:
  • 370 Answers
Try giving it power via the adapter ...maybe the battery has died out ..
Posted on Mar 06, 2009
  • jairolemes Oct 09, 2010
    it is locked, on the record button set it to stand by
I need canon xha1 service manual
http://downloads.canon.com/cpr/software/video/XH_G1_A1_manual.pdf
Nov 26, 2012 | Canon Xha1s Hd Hdv 3ccd Mini Dv Camcorder...
I'm trying to replace the top door on the handle
Hi well to do this you need a service manual, these have exploded diagrams and circuits and schematics too, for your exact make and model, these can usually be obtained via the 'net or through a direct approach to the manufacturer or agent. I have had a search for one but have been unable to find any for free but there is a buy link below too ...? Also accordingly i give you a link, so you can contact the manufacturers agent, to hopefully obtain one?
http://www.manualzone.com/service-manuals/Canon_XHA1_XHA1/users-owners-manuals/ReWrite-SPFM-LNG1.Dyn.M23276519KYWRDS_Canon_XHA1_XHA1_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
http://www.canon.co.nz/en-au/For-You/Digital-Video-Cameras/Professional-Video-Cameras/XHA1
well it seems there may indeed be a FREE manual at this link below... good luck.
http://www.vssm.org/tor/canon-xh-a1-service-manual/
Sep 23, 2011 | Canon Xha1s Hd Hdv 3ccd Mini Dv Camcorder...
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
My canon xha1 is not recording. It says that it is, and timecode runs, but when I go to playback I get the blue screen. I cleaned the heads, no luck.
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 14, 2010 | Canon XH A1 Mini DV Digital Camcorder
The lcd screen on my canon xha1 is displaying everything upside down, why is this and how do I fix it?
The most likely cause for this is a damaged or defective component on the flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to usually be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 12, 2010 | Canon XH A1 Mini DV Digital Camcorder
How can I clean finger marks of an lcd screen on my canon xha1 video camera without damaging it. What is the best way?
Please follow the below link, it will guide you to a perfect way to clean a camera lens and LCD.
http://www.digicamhelp.com/camera-care/cleaning/microfiber/
Sep 08, 2009 | Canon XH A1 Mini DV Digital Camcorder
Help
look for a small pinhole, then insert a pin with batteries in to reset the camera
May 28, 2007 | Canon PowerShot A520 Digital Camera
Canon XH A1 Mini DV Digital Camcorder Logo
452 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
