Question about Microsoft Xbox Console
One flashing red light.
There is one red light flashing in the bottem right on the ring.
    Problem Solver:
  • 19 Answers
Usually with 1 red light errors, there will also be an error that shows on the screen like e73, e74, e75, etc. You will need to first get your secondary error code.
then enter either the e-code from the screen or the secondary error code into the repair guide
Posted on Mar 06, 2009
The forth player icon on the xbox 360 is flashing red
Xbox 360 Red Ring of Death Fix Kit
The e74 is an overheat issue. It's also know as the red ring of death (rrod). It is very, very common. The link above covers the entire disassemble and re-assemble of an xbox.. That is if you chose to go that route to repair.
If you have a local Gamestop, they may be able to repair it for a fee.
Jan 06, 2014 | Microsoft Xbox 360 Console
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 ( ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 ( ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 ( ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit ( , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit ( for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
i order to fix the 3 red lights on your 360 u must take it apart all of it and then clean it from top to bottem and then put back together when the light s flash it does not mean your 360 is broken ight it just means you need to clean it
Oct 31, 2008 | Microsoft Xbox 360 Console
My 360 got a red ring
Here is a guide to possible diagnose the issue.
RROL (Red Ring Of Light) = / \
If the Two left, or the Two right light are flashing, it means that the AV cable isnt securely connected, or the system is overheated.
If only one light is blinking or lit, than it is an error code. It will need to be repaired.
If three rings are flashing, it is a hardware failure and it will need to be repaired as well.
Jul 06, 2008 | Video Game Consoles & Games
Microsoft Xbox Console Logo
144 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
