Question about Refrigerators
What do I do to the fridgerator when I turn off the power
I want to shut the power off to my house...Will that ruin the refridgerator? It is clean and nothing is in it.
  • Anonymous Mar 06, 2009
    MY House is cool and will not reach above 100 degrees during the period the power is shut off. From your answer, I should be alright if I shut off the power as long as I leave the doors proped open, correct? The Frig is a GE Profile.
  • gineric4 Mar 06, 2009
    The frig is in a cool place in the house and it is not in any sun light so it won't get over 100 during the period of time I have it shut off . Do I just leave the doors ajar and turn off th power and will be ok. I probably will have it off for a month.
    President:
  • 267 Answers
It all depends on where you live and how old your fridge is . if you live where the inside of your house can reach 100 degrees you may have damage to your door if your fridge was made after 1995 if it was made before that date the foam in the door can take 140 degrees before it expands and damages the door . never leave a newer fridge in the sun , the door will expand and be ruined ..cold will do nothing except to the ice and or water in the door systems . i hope this helped , you did not give me much to work with . dont forget to prop the doors open a little , good luck ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 06, 2009
  • BOB  BROWER
    BOB BROWER Mar 08, 2009
    thats it . power off and doors proped open a little .... just a note : allways turn off power at breaker or unplug ..... do not just turn off the thermostat , there will be parts of the fridge that will contune to run
Fridgerator wont blow cold air
You wither have a bad compressor, or there is a leak in your cooling system leaking refridgerant. Have it checked by an appliance service co.
Apr 30, 2012 | Cars & Trucks
When the fridgerator is running it sounds like a rattling noise is comming from a fan in an area somewhere behind the ice maker. Also when the the freezer door is opened it stops and then starts again...
Some refrigerators have a circulation fan that blows into the refrigerated section. If yours is designed like this, it will be a blower separate from the coil fan and likely harder to access. I suspect the bearings on that blower are dirty or damaged.
Dec 13, 2017 | Samsung RS2530BWP (25 cu ft) Side by Side...
Hi my refridgerator is not cooling and the fridger section is also not working, every thing is been melted. we can here the refridgerator running but its not cooling.
b44df16.jpgIs the fan motor running below and the coils clean? 8dff5ce.jpg6e3f9f7.jpgIf nothing is running but the light is on you might have a stuck defrost timerb365bb7.jpg
Aug 30, 2010 | Kenmore Refrigerators
My ac unit works sporadically. Today it cooled
First check your filters to make sure they are clean and you have proper airflow.
If they are clean, then you either have low refridgerant or dirty coils.
The outside coils can easily be cleaned by disconnecting power to the unit, then using a water hose to spray off the dirt, grass, etc.
The inside coild can be very difficult to get to on some units and require a special evaporator coil cleaner. As for adding refridgerant, the Law requires one to be certified for purchasing or working with refridgerant so you may need to call a service tech for that. Expect a bill from $100 to $225 for a typical system recharge depending on how low it is and which company you call.
Oct 10, 2009 | Whirlwind FH-778 Air Conditioner
The refrigerator is collecting water under the veggie drawers. The model is ET18UMXGN0 2.
The fridgerator needs to be defrosted, take everything out of the freezer and refridgerator and unplug it for about 8 hours to allow all the ice to turn into water and then clean out all the water and clean the fridge and make sure it is all dry, now turn it back on and it should be good to go.
May 10, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Refridgerator water dispenser doesn't work.
Thanks for all the answers for this problem that seems to happen to many different fridgerators. my fridge just needed to be on for 12 hours before everything begins working.
Jul 24, 2008 | Refrigerators
Kenmore elite refridgerator
My kid left the freezer door open all day. when we noticed, the freezer seemed to not work even when shut off then started again. Is it ruined?
Jul 07, 2008 | Freezers
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
