Question about Acer Aspire 5610 Notebook
Orbicam it's not working on yahoo messenger, i use the usb2.0 camera but nothings happening its just a black screen
  • megax01
    megax01 May 11, 2010
    Is the camera working at all? or with any other applications?
Why does my webcam show a black screen?
Which version r u using? 8 or 9 beta?
1.for 9 beta:
*Can you see your cam clearly? I mean no black screen.
If your web-cam is having black screen, then you have to set it.
On main messenger screen:
click messenger
click connection
tick "connect directly to the internet"
click apply and ok.
Then open your cam and check if it working or not.
*Visit:
http://help.yahoo.com/l/us/yahoo/messeng...
2*Follow the steps below to change your camera source.
Click "Messenger"
Click "My Webcam.
Click "Messenger" again.
Select "Preferences."
Click "Webcam."
Click "Camera Source."
Click the pull-down menu and select the camera you want to use.
Click "OK."
*Best is to visit following link:
*Messenger 8 :
First, please check your connectivity settings within Yahoo! Messenger to make sure you're not connecting through a proxy server. Here's how:
Select " Yahoo! Messenger."
Select "Connection."
Select "No Proxies."
Click "OK."
Close Yahoo! Messenger completely and start the program again. This should eliminate the error message.
please visit these site
www.autodirectmarket.com , www.autoloanph.com to learn more
Apr 28, 2011 | Yahoo Messenger
WEBCAM NOT WORKING WITH YAHOO MESSENGER
try to go to yahoo messenger and then preferences and look for the camera source, make sure that the camera source is your webcam if its not choose it, try it and then tell me if it wont work.
Jun 02, 2009 | Logitech 961462-0403 Webcam
BLACK SCREEN ON MESSANGER
  1. Click the "Messenger" menu in Yahoo! Messenger and select "My Webcam."
  2. Click the "Messenger" menu in Yahoo! Messenger and select "Preferences."
  3. Click the "Webcam" category.
  4. Click the "Camera Source" button.
  5. Click the pull-down menu and select the desired camera.
  6. Click the "OK" button.
Dec 09, 2008 | Acer Aspire 5610-4648 Notebook
ACER ASPIRE 5570 BUILT-IN ORBICAM PROBLEM
Seeing it used to work, have you tried doing a System Restore? If you can remember when this started happening, you may be in luck. Just hold down your Windows key (usually between the CTRL and ALT keys on your keyboard) and hit the PAUSE-BREAK key. Then, click on START | PROGRAMS | ACCESSORIES | SYSTEM TOOLS and choose System Restore. If you have a restore point around or before the date this problem happened, click on it and let it go through its steps. Try that.
Dec 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5570z orbicam driver
As you have said to go to http://support.acer-euro.com/driver/notebook/as_5570.html to download the Orbicam driver for Win Xp OS, I have done it but it is not working with my labtop so, pls advise on what to do next.
Deepsea
Dec 11, 2007 | Acer Aspire 5500 5570-2609 Laptop
Orbicam Problem
its a camera ofcourse it works offline, but it is built to use with windows live messenger and not with yahoo
Dec 09, 2007 | Acer TravelMate 2300 Notebook
Acer's built in webcam
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Nov 10, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 5610 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
