Question about Toshiba Satellite A205-S4617 Notebook
Sattellite A205-S4577 i WENT TO SAFE MODE THEN SISTEM RESTORE THEN START TO CONFIGURATE FILES AND NEVER STOP iWENT BACK TO SAFE MODE ALL OPTIONS , AND BACK TO THE SAME DO NOT STOP NO WAY TO MAKE WORK (SORRY MY POOR ENGLISH)
    President:
  • 1,223 Answers
Pls restore ur system like this pls rate me FIXYA for this help
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Posted on Mar 19, 2009
Windows cannot find
will the computer boot to an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jun 07, 2013 | Computers & Internet
Gateway dx4710-05 will not start upgoes to repair , will not repair
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Gateway DX4710-05 PC Desktop
Acer aspire ast180-ud400
You have no stated what sort of problem?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Acer Aspire™ T180 PC Desktop
System stops working until reboot
Step 1:
You might have a virus or malware or it could be a hardware issue
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials if this fails you might have to go back into safe mode you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. other than that you might need to do a format and then re install your operating system
Feb 23, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
Windows xp contineous reboot after installation of Avira antivirus
You might have other issues other than antivirus ?
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then uninstall Anvira then you might restart to see if the problem is resolved if not start in safe mode again
Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps
Jan 21, 2013 | Computers & Internet
I have a Latitude D600 It is 5 yrs old and I have forgotten my user name and password, I have tried F8 repeatedly, this takes me to safe mode and then to log on. So I am back where I started. Can anyone...
Write down a list of possible passwords. Try to remember which passwords you were using when you first got the computer. Alternately, try the password "administrator".
Jun 24, 2011 | Toshiba A205-S4577 Notebook
Netbook Acer Oner N270 Atom 1.6GHz doesn't start, I tried to run a chkdsk thru F8, but the sistem prompt never shows up when I ran in safe mode with command prompt. Thru F8 i was able to see a while...
Hi
Did you try to go back to last known configuration in the F8 option
or the repair option
failing that try a system restore in the F8 option back to when it was running ok
failing that also you could try to get back into safe mode
go to start run/search box
type in cmd
this Will bring up a black box
type in CHKDSK
that should check disk and hopefully give option of repair disk as well
but it will take some time but be patient
Or try to get to the acer recovery
i have never tried the recovery in safe mode but it hopefully will except it then restart into the recovery management
this is where you find it ( in or out of safe mode )
start programs
acer
acer empowering technology
acer erecovery management
recovery
follow on screen instructions
good luck
hope you get sorted
Feb 18, 2011 | Acer Aspire One AOA110-1588 Notebook
Windows shows that file assm of Service Pack 2 is missed and I can not start the computer. It asks me to type a path to assm file. What should I do? Where to download and how to make it acessible
Hello over there :O)
Try to start your computer in safe mode; you do this in this way : Start the computer and press the " F8" button and then you come in a menu mode. Here you choose "start the computer in safe mode". Here you choose to restore your computer in a early date (system restore). You find the app in : Start-All Programs-( Applies )- Sistem Applies- Sistem Restore. You can also find this feature in "help and support" in the start menu.
Hope that helps
If not then try to return here
Please rate my answer :)
Jun 10, 2010 | Microsoft Windows XP Professional With...
Toshiba Laptop A205-S4577 won't start up
If the battery is removed, it should still start up with the charger connected. A lot of laptops develope problems with the jack where the power supply plugs in, from constantly plugging & unplugging the charger. The jack in the back of the computer is probably bad.
Jan 15, 2009 | Toshiba A205-S4577 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
