Question about Air Tools & Compressors
Compressor oil NEED TO KNOW WHAT OIL IS COMPATIBLE WITH SYNTHETIC OIL FOR THE COMPRESSOR. INGERSOLL RAND 185
    Scholar:
  • 104 Answers
PLease contact IR http://www.irtools.com/serviceandsupport/techpubs.aspx
and direct this question to them. You do not want to make a mistake here as it will cost you a compressor. I would only accept what IR says is acceptable
good luck
Posted on Mar 17, 2009
Craftsman service manuals
I am assuming your enquiry is about the type of lube oil used in the pump section of the compressor. It would have helped if you had provided the model number of the compressor. In any case craftsman suggests all oil lubed compressors use synthetic non-detergent compressor oil.
Something like this would be required.
http://www.sears.com/ingersoll-rand-ingersoll-rand-38440228-compressor-oil-synthetic/p-SPM2881704102?prdNo=1&blockNo=1&blockType=G1
Aug 13, 2014 | Air Tools & Compressors
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
Model 2545 compressor getting toomuch carbon deposit in side the cylinder
You can try switching to a full synthetic compressor oil to alleviate the problem.
Carbon is caused by the over heating of oil. Your problem is most likely an undersized compressor, or worn valves and piston rings.
Regardless of the problem synthetic compressor oil will help.
Hope that helps,
under_psi
May 16, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
WHAT TYPE OF OIL CAN I USE IN MY TYPE 30 COMPRESSOR
I am sure Ingersoll Rand would like you to use there all season select synthetic oil, or you can use a good quality R+O 100 oil, also known as SAE30 non detergent. do not use cheap oil for gas engines,,, buy a good name brand from a regular oil distributor, and specify yo are using it for an air compressor. and most manufactures will recommend you change it every 3 months.
Jan 08, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
317 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
