Question about GE Security Bc 1500 2.5 Ball Camera, High Resolution, 480 Tvl Color, 2.5mm Lens, 10 40 vdc/18 30vac
Not able to use remote viewing via no-ip
Able to set up and see dvr on the network, locally with no-ip account; but when at another location, tried to view remotely via no-ip account with the provided qsee viewing, not able to log in. . . keep on getting a connect failure with reason (-3) no stream timeout. . . is there a particular setting at remote site/computer that need to set
  • Anonymous Mar 12, 2009
    where do you go in the firewall settings to resolve this issue?
I had the same exact issue. I was using dyndns to connect, but i found out that when you login in the host, dont put your local ip address of the dvr, but instead put the internet ip address of your network. so instead of 192.168.0.5 for your local put the 89.137.24.124 for the internet address. That fixed my issue. Hope that works for you. Just make sure your username and password is right and the port is set up correct in your router to forward to the local ip of the dvr.
Posted on Mar 27, 2010
  • 3 Answers
I assume that the cameras are operating fine at the location. This is a little involved for the average do it yourselfer. The computer at the DVR location Is windows I presume. If not we'll stop right here & go our separate ways. Otherwise at the computer desktop go to Start ... run... type in CMD. At the black screen type in "ipconfig" ...enter. Copy as much of that info as you can you will need it. Type exit to exit. If you can view the cameras on site but not away fron there, then you need to get into the router & enter specific info into the " port forwarding" section. All routers are somewhat different but the terminology is the same. How do we get into the router??? that info you copied will tell you the router address to use in the explorer or Firefox address window. Most are usually 192.168.0.1 OR 192.168.1.1 depending upon the mfg. On your DVR software you should have specified an IP address for the dvr if not do so now. Make it something unique like 192.168.0.150 or whatever. Don't forget to enter a port address... 7000 works well for this type of setup. Now back at the router, find the port forwarding section hiding within the software & identify the dvr as such, & enter the IP address that you just assigned to it in the dvr software. Enter the appropriate port number & save the info to the router. Now you can test the settings. Locally you can use either the 192.168# for access or you can use the outside ip address that you got fron the ipconfig screen don't forget the port address.
If all of your settings are accurate it'll work. Also be sure that the Caps lock is on or off. Often you can just go to the windows address bar & type in the address of the dvr ... 192.168.0.150:7000 etc. One thing to keep in mind, the better the upload speed of the dsl connection the better the picture will transmit. Slow upload speeds result in a jerky picture. Verizon FIOS has about the best dsl upload speed... cable is a close second. Good luck
Posted on Apr 03, 2009
  • 463 Answers
There's a firewall in your way somewhere.
Posted on Mar 06, 2009
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Mar 23, 2015 | Gateway Computers & Internet
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
Cann't connect to wj-hd716 via network
Hi
in some case, you need to check the compatibility view settings in the Microsoft IE.
- go to "Tools->Compatibility view settings"
- add the ip address of your DVR
- try open the DVR web.
Feb 17, 2014 | Panasonic Wj-hd716/4000 16-ch Real-time...
Can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
May 23, 2010 | Samsung 4 Channel Dvr
I have a sentient 4 channel cctv DVR with networking. It works ok locally but, I am having problems setting it up to view via the internet. I have a wireless router with a static IP address. I have tried...
have same unit colin and was a nightmare to sort but finally did it.
you need to set up port forwarding on your router and set up dydns account and switch on the service on your dvr. enter details on dydns page on dvr.
if you cannot log in via web address provided by dydns try entering your ip add with port your forwarding like this 89.79.89.87:9950
hope this helps
Mar 21, 2010 | Computers & Internet
To veiw on the web I have to be home how can I make it operate from whereever I am even out of state?? Thank you Dan Richardson
Setting up DVR to be used from remote location:
  1. Connect your DVR to your router
  2. Use menu on DVR to assign internal IP and gateway and port number.
    This Local IP must be in the same Gateway range as the Router. If you are unsure check the Router and locate the Status section, or goto the command prompt of your windows operating system and type in ipconfig.
    Look for Gateway. If the Gateway is 192.168.1.1, then you can make the DVR's IP anything from 192.168.1.2 - 192.168.1.255.
    Also you will need to use the same SubNet Mask, which is typically 255.255.255.0, and also use the same gateway.
  3. Next find out what port your DVR uses. The easiest way to it is by reading the manual of your DVR. Look for the network section of it.
    Also if it comes with network software, check out if in the connection area the software shows the port number.
    Also check the Server software/Programming (Network section of it) to see if the port is listed.
    In many cases it will be as simple as just Port 80, which is an HTTP port.
  4. Set your router to forward chosen port to internal IP address of DVR.
    To access the Router itself, use the Gateway you just located. If the gateway is 192.168.1.1, then enter that into the location edit box of your browser and then click the Enter button. A username and a password are typically required, but it depends on a router. For Linksys use "admin", "admin". By default DLink doesn't require any username or password (It is highly recommended to change the default password).
    Once you're logged into the Router, in the Applications & Gaming Section / Servers of the Router, you need to add a Server/Application. Enter the port number and select TCP only. Where it says Port 0 to 0 enter the same port number twice. Or if your DVR uses for example, ports 3550, 4550, 5550, 6550, and there is nothing else utilizing these ports in between, then you can actually just enter one line, 3550 - 6550.
    Enter the DVR/Cameras internal IP.
    Enable it.
    Quote: Originally Posted by Example If the port was 1024, and the Local IP is 192.168.1.200, then it would be:
    NAME = Anything you want
    Port = 1024 TO 1024
    TCP/UDP = TCP
    LOCAL IP = 192.168.1.200
    ENABLED = CHECKED
    OR
    Port = 3550 TO 6550
    TCP/UDP = TCP
    ENABLED = CHECKED
  5. Set up additional entries for as many ports the DVR uses, to the same local IP. Check your DVR manual and it's networking section for all additional ports required. Also check the DVR software itself.
    If your router has enough free entries, you can seperate them. Use it like DVR_HTTP for the browser port, DVR_AUDIO for the audio port, etc.
    If you are going to use VNC to a PC DVR, then you would need to set up port 5900, and perhaps call it VNC_DVR, for example.
  6. You have a static IP so you don't need to use sevices like www.dyndns.org . You just enter your static IP and your router forwards packets to your DVR.
This info is from Stream recording found on http://stream-recorder.com/forum/connect-dvr-via-internet-watch-cctv-cameras-t1996.html?s=16e8433689f2d55effb40b16d5588895&
Nov 29, 2009 | Samsung 4 Channel Dvr
I want 2 configure a DVR from remote place and not from the intranet. kindly help me out in solving the issue
To configure the DVR from a remote location you can do it one of two ways:
Create a vpn connection through your router if it supports it or an external units to the remote location. This will make the remote location appear to be local to the dvr.
You can also setup the dvr's internal IP and port on your router through port forwarding. This way certain network access or traffic will be passed directly to the dvr from outside your local network.
Nov 12, 2009 | Dome 4 CCD CCTV Camera Surveillance...
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Q-See System Not Listed in available computers
http://www.portforward.com/qsee/
Choose the model of your Q-See DVR and then select the model of your router.
Nov 11, 2007 | 2wire 2700HG-B Router (2700HGB)
GE Security Bc 1500 2.5 Ball Camera, High Resolution, 480 Tvl Color, 2.5mm Lens, 10 40 vdc/18 30vac Logo
2,504 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
