Question about Refrigerators
My hot point refrigerator will not cool or freeze.is there
My hot point refrigerator will not cool or freeze the fan is blowing warm air.Is there a reset button or something? model ctx21easmrwh
    Problem Solver:
  • 8 Answers
Let someone check the pressure of you FREON that is one of the problem need to look on
Posted on Mar 06, 2009
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
What is the problem now? Please can you help?
If you turn on your AC on one day and nothing happens, you may be dealing with a major component failure. Your vehicle's AC system consists of a compressor, condenser, evaporator, expansion valve, a series of tubes and several fans/blowers. If either one of these components fails to do their job, it may result an entire system failure. For example, if the evaporator blower motor burns out, you will get little to no airflow through the vents.
Most modern vehicles also have safety mechanisms that may prevent a component from engaging if the pressure is low in the system due to a refrigerant leak. Refrigerant can leak for many reasons, including undone welds, loose connections, corrosion, physical damage from road debris, etc. Look for oily stains underneath your car, as they may indicate a leak. If you suspect a refrigerant leak, take your car to General Automotive. We will test the pressure and use special dyes to pinpoint the leak.
Warm Air is Coming Out Instead of Cold As you get in your car and turn on your AC, you probably expect it to be blowing hot air for the first minute or two until the system cycles through enough to cool it. But what if the air never gets cold ? Or maybe it it gets cooler, but not cold enough ? No, your car didn't get confused and turned on heat by accident. There is likely a problem with your condenser.
A condenser's job in a vehicle is to cool the warm refrigerant that was used to make the air cold in the evaporator. A condenser has coils and a fan to push the air through the coils and thus cool the refrigerant. If the condenser coils get dirty or clogged, or if the fan fails, the refrigerant won't be cooled completely, so the air will come out warm. It's best to take your vehicle to an experienced AC Repair professional to troubleshoot this problem if you don't know your way around under the hood.
Cold Air Blows Intermittently So you went for a road trip or a long drive, and after 30 minutes of driving realized that your AC suddenly stopped working or switched to blowing warm air. The cold air returns shortly, and the cycle repeats itself for as long as you are driving. What's wrong with your car?
Intermittent cooling is often caused by the components of your vehicle's AC system freezing up. Typically an iced over evaporator is the culprit. An evaporator covered in ice can't cool the air, so you would have to wait until the ice melts, which is why the cold air eventually returns. There may be numerous issues causing the icing-from a dirty cabin air filter to a blocked evaporator drain or an overcharged system. Look for puddles of water under your car-this could be a sign of a freezing problem.
Oct 25, 2017 | 1999 GMC Safari
REFRIGERATOR TEMPERATURE IS WARM, & FREEZE TEMPERATURE IS ALRIGHT
This has to do with the diffuser that lets the cool air into the fridge side not opening or the fan in the freezer not turning on to blow the cool air into the fridge. For ferther detail on how to perform repair please reply.
Please rate my solution if it was helpful.
Thanks, Repairman45
Dec 02, 2010 | Amana Refrigerators
My Kenmore side by side Refrigerator Model No. 253.55679403 will not freeze or cool, ice is melting and food is thawing. Light comes on and I can hear a fan or something, but I'm n ot sure. Can you help?
if you hear a fan in the freezer section when the door is open. feel the bottom of the fridge for hot air blowing. if you dont feel any hot air at the bottom, the condenser fan is the problem. if you do feel hot air then you have a defrost issue.
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Why does my air conditioner in my car blow out hot air? one minute, it'll cool just fine and the next minute, it blows out hot air.
Assuming you are not low on freon:
I have seen this symptom caused by too much moisture in the system too, it freezes near the metering device which kills the refrigeration effect which makes it warm up, the ice melts and it starts working until moisture builds up and freezes which kills the refrigeration effect again.
Jun 02, 2010 | Whirlwind FH-778 Air Conditioner
Amana arb2517cb is running but not cooling or freezing. What might the problem be? The fan is running, blowing cool air.
If in the freezer is warm and the compressor not running but fans are then we need to start at compressor by unplugging and pulling away from wall remove the cover over the compressor and feel the top to see how hot. If too hot to keep hands there leave the plug out of the wall and tell me and I will help or if you don't feel like this is something you can do then it may be better to call in service. Let me know, Sea Breeze
Dec 20, 2009 | Amana Refrigerators
Amana heat pump freezes up
Hey there, there re a couple of reasons that an ac unit freezes up. The first thing you need to do is defrost it. Then, check to make sure your filter is clean, the side of the coil the air hits first is clean and the scoop on your fan wheel are clean. Next, start it up wait about two minutes then feel the larger line that is covered in black insulation. Normally it is about 55 degrees. If it is colder, you have an airflow problem (dirty fan, coil, filter) if it is warm, you are probably low on refrigerant. If the line is warm, see what temp the small pipe is. If it is cool, you have a restriction in refrigerant flow somewhere. If it is warm to hot, again pointing to low on charge. Let me know what you find out or if you need anything else. Oh yeah, if you are low on refrigerant, make sure the leak is found and repaired or the problem will keep coming back
seth
Jun 27, 2009 | Heating & Cooling
FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Nov 30, 2008 | Frigidaire FRT18G4A Top Freezer...
Not getting cool enough
try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
Jun 23, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
