Shared telephone ling malfunctions sometimes
I have a fax number shared with my telephone line. It malfunctions when recieving a telephone call - only sometimes and on only two numbers. When someone tries to make a telephone call to me from those phones they often get my fax. I have tested to make sure they are are calling 813-8378800 and not my fax number. 813-8378860. Please help! I have given you all the correct information. Why isn't this getting through?! Product is correctly identified
  • 27 Answers
It looks like you have a distinctive ring service from your phone company. Change the ring pattern of your fax to its assigned ring pattern (double or triple ring). It could be assigned to 'all rings' right now, that's why your fax is picking up your landline calls as well.
Posted on Mar 06, 2009
Fax won't answer
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
When I try to send a fax on my lexmark x4650 it has error no dial tone?
If you are getting "no dial tone" as an error on your fax machine, it means that you have the telephone cord plugged into the wrong port on it.
Turn the printer around so that you can see the back of it. If you look closely, there should be three ports to choose from in which you connect a telephone cord. Sometimes they put a little white plastic piece in the ports to keep them clean during shipping ect. If this is the case, go ahead and remove them now.
If you look closely at each port , you might notice that they have text or pictures right above or below them to tell you which one to use. let me explain; if you have one telephone line and wish to use it for both fax and voice calls - you will need more than one port. That's why they mark them.
One of the ports should say "line" or have a picture with a funny little symbol on it. This is the port that you would use if you want to fax someone using your printer. You plug your phone cord into this port on your printer.
One of the ports should say "phone" or have a picture of a telephone by it. This port is used when you want to share a single phone line with both your fax machine and telephone used for making voice calls. To split your line between both fax and phone, you plug your phone cord from the wall into the port marked "line" and take a second phone cord and plug it into the port on your printer marked "phone" and the other end of that line goes into your telephone (voice line).
The last port should say "line 2" or similar and usually has no picture next to it. This is an additonal port to share with a second phone line.
To correct your problem of "no dial tone", plug your phone cord into the socket on the wall and put the other end into the port on the printer that says "line". Now lets test the connection.
Put a piece of paper into your printer, press the fax button and dial any phone number using 1 and then the area code followed by the phone number and press 'start" or "ok" to begin the fax. If you have chosen the right port to connect your telephone cord, you will hear a dial tone first, and then dialing of the numbers you chose. If you cannot hear a dial tone before your numbers begin, then you have not chosen the right port. If this is the case, remove the phone cord from the port you have chosen and try another until you do hear the dial tone.
NOTE:
Do not try to go from your phone jack into your telephone and then use a second port on your telephone to connect a second phone cord that is plugged into your printer/fax. A second phone port on your telephone is most likely for a second phone line to use for voice calls. The majority of phones for residential use do not have a built in splitter that works like a fax/printer does. If you try to use a second port on your phone to split to your fax machine, it usually will not work. Follow the instructions as listed above to re-route your line and correct the problem.
MAGIC JACK USERS:
While magic jack is great for making free long distance calls, it is not suggested for use with a fax machine. if your trying to use your magic jack phone line to fax it usually does not work.
Jul 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I have a fax number shared with my telephone line. It malfunctions when recieving a telephone call - only sometimes and on only two numbers. When someone tries to make a telephone call to me from those...
Mar 06, 2009 | HP Officejet 5510 All-In-One Thermal...
Phone line gets busy tone while recieving fax in DRPD mode
As I understand it, this is as it should be. You have two different numbers sharing the same physical line and only one can be active at any one time, so if you are using the phone and someone tries to fax, the fax line will be engaged and similarly, if you are sending a fax and someone tries to ring on your phone line, it will be engaged.
Nov 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
SHOWING RECIEVING FAX
If you can send and receive faxes from other telephone numbers, do not worry. However is sending that annoying fax has humidity issues with his phone line.
Be blessed.
Oct 06, 2008 | Samsung SCX 4521F All-In-One Laser Printer
I can send faxes, but cannot receive faxes.
Thank you for specifing your connection>
When you have a shared fax line it is import to have a Distinctive Ring Pattern which will differenciate the type of ring patter to recieve voice calls and Fax message.
All You need to do is get a distinctive ring pattern from your telephone service provider (AT&T) and setup your fax machine as per the ring pattern provided by your service provider.
All you need to do is set your rings to answer in youe phone to Rings 4 in your Phone.
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate basic fax setup> Press Ok and set the Ring Pattern to Number 5 or 6> Press Ok and cancell to come to the main menu
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate Advance Fax Setup> Locate Distinctive ring pattern and set it to the ring pattern which your Telephone service provider has alloted i.e Single Ring, Double Ring or or Triple Ring (Whichever is applicable)> Nd press Ok and cancell to come to the main menu.
Then you will be able to receive fax message voice cals and voicemail without any interuption.
Good Luck
Sep 25, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Multiple fax copies only 1 or 2 get through
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
Jul 09, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
81 people viewed this question
k24674
jasbo
jasbo
